I've been doing regular used oil analysis on our MT665B Challenger tractor. Tractor has a Sisu 8.4L engine. Tractor is used almost exclusively to pull our 30', tri-axle manure spreader. The previous two used oil analysis were with Service Pro 15w40 CI-4+ whereas the most recent was with Service Pro CJ-4. Tractor currently has 3388 hours. Engine is equipped with a centrifugal bypass filter which was part of manufacturers recall. If not listed its a 0.
Code:
Hrs. 220 250 300
Iron 29 31 20
Chrm 1 0 0
Alum 1 0 0
Copp 2 1 1
Lead 1 1 2
Tin 1 0 0
Sili 6 3 5
Sod 4 3 2
Pot 0 1 0
Moly 85 50 96
Bor 10 16 2
Mag 1161 914 807
Cal 1550 1303 1182
Bar 0 0 1
Phos 1340 1006 1050
Zinc 1504 1182 1188
Soot 1.5 1.9 .4
Vis 15.3 14.4 14.7
TBN 7.4 7.04 6.19
Ox 10 9 9
Nit 16 17 16
I was impressed by the reduction in soot. Does the formulation of a CJ-4 oil allow the soot to filtered out easier? This oil change I used Mobil Delvac 1300 which I got for like $6 a gallon after mail-in-rebate. Might try and push OCI to 400-450 hours.
Code:
Hrs. 220 250 300
Iron 29 31 20
Chrm 1 0 0
Alum 1 0 0
Copp 2 1 1
Lead 1 1 2
Tin 1 0 0
Sili 6 3 5
Sod 4 3 2
Pot 0 1 0
Moly 85 50 96
Bor 10 16 2
Mag 1161 914 807
Cal 1550 1303 1182
Bar 0 0 1
Phos 1340 1006 1050
Zinc 1504 1182 1188
Soot 1.5 1.9 .4
Vis 15.3 14.4 14.7
TBN 7.4 7.04 6.19
Ox 10 9 9
Nit 16 17 16
