Chonda 2.5hp engine?
Nick--try an UNLIT propane torch around the assembled gasket mating surfaces---> increased rpm at a spot and you've found your leak/surging area
Had a redlion 208cc 2" pump . not a predator or greyhound . but wac china cheapo. ran great out the box. Talked tsc into a few qts of there syn5w-20. Ran first is of oem provided oil 30minutes changed to syn. ran 1, 5, 10hr oci and went to 50+hr oci's.
Was stolen with a minimum of 1000-1200hrs. ran like the day it cam out the box. no smoke, oil burn or leaks.
ran whatever 5w20 was around.
ken
HF has the 6.5hp 212cc is on sale for $90. I got one today to repower the gokart. the 5hp funpower is aa heavy smoker but runs strong. ran it for 15minutes (bench test).. filked with half quart amsoil 30/ 10w30 4stroke oil, 2oz of acdelco eos, 2oz redline breakin addive. i will be running syn oil probably so i started with some leftover amsoil.
ken
