I think you will like this fluid extractor when you use it to change oil in your BMW. Post your experience/question(s) after you received and used it.
To tighten the screws on black top you need 8mm wrench to keep the nut under it from turning. Don't over-tighten it, you may damage the seal under the black top.
One importance note: push the large tube to the container firmly until you hear a click, then pull the blue cap out a little to seal it, otherwise you may have a small air leak. To remove the tube from the container use one hand to push in the blue cap while the other hand pull out the tube.
You made a right decision in going with the Amazon warehouse deals, who really cares about the box, damaged or not.
