1stTruck, there's a date of submission listed on the paper above, so that's likely the best way to judge when the oil was bought. It's probably regular M1 5W-30. All motor oils have additives that compete for bonding to the engine's metals so this is not unique to the oil in this test.
BarkerMan, some posters here have noticed that the boron atom, as measured by UOAs, does show it is partly "going off the radar". I've never seen it all disapear but have seen significant percentage decreases. Where it goes or why it goes off the radar is uncertain to me. Possibilities I see are:
1. It's very volatile and some of it evaporates out of the oil at a much higher rate than the rest of the oil volatizes
2. It gets filtered out after it bonds to something else which makes the molecule it's part of big enough
3. It falls out of solution
This paper indicates it's not likely not bonding to metal surfaces so we can likely rule that out as a possibility. Plus the concentration decreases are high enough that the metal surfaces couldn't accept that much buildup indefinately without issues arising.
What oil or oils did you use that allowed the buildup in the oil pan? And did you have the buildup tested chemically or at least feel it to check its consistency?
BTW, yes I think it's certain that sampling technique affects UOA results.
