Checking PCV Valve on a 2.0 Skyactiv
NJ
So after having the OCV issue which is now fixed I wanted to check if the PCV is clogged. There are a few simple things you can do without going through the hassle of removing the intake manifold to get to the PCV in this car.
I opened the oil fill cap and there was very light suction. Before I buy a vacuum gauge, is the suction going to be very light? Also, should the suction increase as someone gives the engine a little throttle? The way I did it was with no one in the car giving it any throttle.
