They recommend replacing every 7-10 years regardless of how they look.
Here is a 6 year old hose I just replaced.
Also if using with a frontloader find ones that have at least 1/2" inside diameter for efficient rinse cycles.
They are usually marked as high flow or high efficiency hoses.
its hard to tell in the pic I'm posting below but the bulkier right hose is about 30% bigger inside diameter.
The "silver" hose looks the same diameter but it isnt.
Since frontloaders "spin rinse" vs a top loader that refills
its important that your hoses can flow enough rinse water to make the cycle efficient.
I replaced with these rather spendy hoses.. and I wanted 4' but good luck finding all that.
https://www.homedepot.com/p/Homewer...ng-Machine-Fill-Hose-Pair-HRBFIL07B/305341002
Another oddity: The bad hose was the cold water hose.. the hot water hose looked 100% mint brand new shape...(figured the hot water side would look worse?)
must have been a defect.
