Cheap rustproofing Oil?
Canada
Thanks to everyone who helped out with my post and the humming noise.
It was my bearings and the problem has been fixed.
Like I said, thank you for taking the time to post.
My question now regards rustproofing on the cheap.
My car has 250 000k and I'm under no illusion that it's days are numbered. I'm hoping to get another year out of my 323 and with the harsh winters here in Ontario I'd like to do some rust prrofing on the cheep.
Any suggestions, like old oil?
Cheers
Thanks in advance.
I tried oil. It washes out and dries out before winter is over. Don't waste your time with it.
For the past 20 years I've been spraying Texaco rustproofing compound on my vehicles. I buy it directly from the distributors. I spray it heavy and it costs about $20 per application. I apply it with a paint gun and an attachment I fabricated in the garage.
I found the receipt!
Contact info:
dba Consumers Petroluem Co.
13507 Auburn
Detroit MI 48223
313-272-3800
(it's near Schaefer and Schoolcraft for any of you locals)
Product No: 01TERC 35TEXACO RUSTPROOFING COMP. L
They make a number of compounds (undercarriage, painted surfaces). Concensus was that Texaco Rustproof Compound L is the best all around material to spray on the car. It has the consistency of grease. It must be mixed with mineral spirits before spraying on the car. The mineral spirits carry it through the spraying process then dries off, leaving the rustproofing compound on the car.
A lot of the rustproofing shops use this compound. That's where I found out about it. I actually visited with an engineer that manufactured Polyoleum and wasn't impressed with that product. The stuff hardens to a waxy consistency and is probably prone to flaking and actually making corrosion worse in the long run. Also, when I was an engineer at Chrysler 20 years ago, the corrosion engineers pointed to this compound as being the best.
Speaking from 20 years experience with this Texaco material, the compound does not harden, but it does need to be refreshed every 2-3 years, especially in the high wash areas, as it slowly dries out over time. The low wash areas, such as blind door cavities, are good for much longer. Some shops using this material usually inform their customers that a revisit for refreshing the application should be done for a minimal fee and encourage such a program. I don't believe in any rustproofing material that is advertised as "good for life" with a single application.
Also from experience I can say this material does an excellent job of protecting all surfaces that are covered. I keep my cars a long time. And Michigan is about as bad as it gets for auto body corrosion. The only rust problems I've had are where corrosion starts from the outside inward, or blind areas like the A or B pillar that are practically impossible to rustproof.
moribund, where can you get cosmolene? VW sprays all body panel interiors with it. When they get hot in the summer it starts dripping out of the car. 11 yr corrosion warrenty, wonder why? Anyway, I want to put something in my saab's panels to keep it from rusting out.
Hey Mazda,
Take a look at Amsoil's Heavy-Duty metal protectant. It sprays out of a 16-oz can, penetrates very well, and dries to a waxy coating. It looks like the stuff that VW sprays in the doors - caramel, waxy - but dries harder and doesn't run in the heat. I've used it in my '96 VW to penetrate into seams that have started to rust. It retails for $5.75 a can.
The Texaco stuff is probably the best way, but this works well and is quick and easy. Andy
Cosmolene is a coating designed to temporarily protect metal during shipment. For any American with a European import, it's the yellow stuff all over the engine components. This stuff gets brittle and it's designed to wash off with an alkaline cleaner. I wouldn't trust it for the long haul in high wash, gravel prone areas.
Cheers
Thanks in advance.
If U live in truly "Salty" environment, the 2 terms: "rustproofing" and "cheap" do not go together. If it is "cheap" it will not be real "rustproofing." Having said that, use "boiled linseed oil." Be careful that U get the "boiled" and not the "regular" linseed oil.
It is not a 1-time deal, though. You have to go back and keep doing it, about every 3 months. But, it works.
