What the longest service one has recived from cheap $29.99 bateries?
Why don't you put a trickle charger on the battery every once in while in the winter to keep it from discharging totally and killing the battery. Those trickle charges are cheap and a lot cheaper than buying new batteries each yearquote:
Originally posted by T-Keith:
I have a $30 EverStart in my Lesabre. Unfortunately the car sits all winter so I usually have to replace the battery every year. That's OK though, 1 year warrantee.If you use the car all the time, expect it to hold up better. I've seen them last alot longer. Make sure the battery has enough CCA for your application too.![]()
-T
I do try. But sooner or later I just forget and the battery gets drained. Hasn't cost me a dime yet.quote:
-T
Whimsey
