Just try to imagine if you had to drive your ICE vehicle in this manner. Most people would become disgusted with the whole "procedure" by the end of the first day.
It's all too reminiscent of the Arab oil embargo of the 70's. Waiting in gas lines for limited purchases, that you had to make on a daily basis, if you had to drive any distance.
I'm still searching to understand how this is any kind of improvement in modern automotive transportation?... Along with how and why some people become so fascinated by it?
I am not trying to get you or anyone else to buy an EV. Potential buyers need to understand that these cars are different then ICE vehicles in many ways; fueling being the primary difference.
ICE cars gas up in a few minutes and off you go. The "charge to destination" EV process is to minimize Supercharger time and expense. My nature is to fill up, but the optimal way can be to make more, shorter time charging stops. Different, to be sure. And that assumes there is available charging when you arrive at your destination and have the idle time. Big assumption IMO.
In 16K miles I have been on 3 Superchargers. The 1st time was to try it out to learn how it works; I was at a Starbucks and plugged in for maybe 5 minutes. The 2nd and 3rd time were on a 180 mile round trip run to our other home in Petaluma. I can make it on a 95% home charge; I did not have to stop. These stops were so I can better understand longer distance EV use.
So I have spent maybe 1/2 hour charging. ICE vehicles have spent maybe 40 to 60 trips to the gas station in 16K miles. So who spends more time fueling? Now add in lubricant services... I can tell you fueling up at home is far better than visiting a gas station.
Now, IMO, it is about your use case and what you want. Use case is key. For someone like
@Cujet an EV would increase his travel time significantly. The #1 reason people go back to ICE is charging issues. There are owners who only charge at work, but they are statistically outliers. Some owners only charge at Superchargers; that has to be expensive and time wasting. I sure as heck wouldn't own an EV if I could not charge at home.
Like any other car, it is also about what you want. Not the best reason, but it's your money.
