Is there any benefit to periodically {once per month/quarterly etc} using a battery charger to "top off" a car battery that sees daily use in a car that has a correctly operating electrical system? Will it extend the life of a newer battery?
Someone told me that alternators rarely charge the battery to 100%, and by periodically using a charger, you force a 100-105% charge on the battery, which helps it? The battery in question is a AGM model, if that makes a difference.
