Changing gear oil in high humidity?
Yowza...heard it was bad. Was the single can enough for the entire TC?
I've read on a couple T4R sites that a lot of owners are using the same 75w-80 as goes in the differentials....[/quote]
I sure hope so. The spec is 1.1quart (75w oil can is 1L). It did start to drip at the end. I tried to peak into the fill hole and couldn't verify the level, but know I got 99% in there and there was probably some residual left in there.
Yes, lots of folks use 75w90. Probably just fine in CA climate.
When we flood in the marsh I have driven through a half mile of moving water several times … After back home … with a clear plastic soda straw (perhaps I need to hide some) I take a sample … if not cloudy … rock on …
Originally Posted by Gebo
OCDollar,
You are not nuts to ponder such a thing. But I believe you have your answer. No worries.
How are you gonna get the lube in the diff and transfer case?
I poured the oil out of the old school can into 2 regular plastic gear oil bottles. Then I fitted a 5/16 I.D. hose on the end, squeezed it in. Worked good and didn't require a pump.
Originally Posted by OCDoiler
Is gear oil hydroscopic or am I nuts to even ponder such a thing?
Don't let these guys get to you, this is a valid question. DOT 3/4 brake fluid is hygroscopic, but gear oil, ATF, motor oil are not. Even brake fluid doesn't absorb moisture that fast, anyway.
Originally Posted by Piston_slap
The water vapor can combine into droplets of water. Have you ever dropped water into a hot, deep oil fryer? Well. same thing here and the new added pressure blows the axle bearings out of the axle housing.
So THAT'S why getting coolant in your motor oil blows the head gasket!!
