Changing fluid...pull the plug?
Scituate MA
02 Grand Carvan planning to change the rad fluid. I am not getting a flush, can I just pull the plug out at the bottom of the rad? I understand it won't get all the fluid out.
Is there anything else I should be aware of when I do that?
Yeah - wear an old vinyl or leather glove, and eye protection because the stuff will be hot. There are two ways to get the old coolant out:
1> remove the block drain plug(s) in addition to draining the radiator - very messy and you will get splashed.
2> repeated drains and refills with water (preferably distilled or de-ionized) until the effluent runs water-white clear. By using distilled or de-ionized, you won't be introducing any dissolved minerals into the system. Calcium is especially bad because it tends to form scale. Do NOT use ion-exchanged softened water. It's full of sodium and that's even worse because it promotes rust in iron and corrosion in other metals (yes, even aluminum will corrode). After each refill, idle the engine until the upper radiator hose is HOT - that's your indication the thermostat has re-opened. Four or five flushes are usually sufficient. Five or six gallons of cheap WalMart distilled water should be more than enough. Make sure the heater valve is set to its hottest setting to assure that the heater core is flushed, too. Once you're satisfied that the old coolant has been flushed, add whatever antifreeze concentrate you've chosen and use a needle-type coolant hydrometer (Prestone and Victor make good ones for about $3.50) to adjust to a 50/50 concentration. Afterword, drive several miles (with the heater control valve set to hot - you don't have to run the fan) to purge the system of air*. Shut the engine down and wait until it's cold, then check the coolant level at the radiator cap. If it's low, top up with a 50/50 mix. Also adjust the level in the puke tank to where it should be when cold. For the next several days, check at the radiator when cold and top up if necessary.
*Check your owner's manual - some cars have an air purge screw to simplify this operation.
I second everything that Ray H said, except that instead of using a coolant hydrometer I check the owner's manual for the cooling system capacity and put half of that amount of antifreeze in the radiator to get a 50/50 mix. Actually, I mix it between 55/45 and 60/40, because it gets from 30 to 40 below almost every winter where I live.
Current OEM brew for DaimlerChryslers is orange dyed G-05. Zerex markets yellow dyed G-05 that can be had for $11.99/gallon at Pep Boys. Chemically, they're identical. What's the dealer price?
The Ford Motor Co. uses G-05 in their vehicles and the dealer price for Ford's version of G-05 was 13 something dollars a gallon last summer in Helena, Montana, where I live.
Local Pep Boys in DC Metro area are same price for Zerex G-05.
My local Ford dealer charge $12.00/gallon for Motorcraft Premium Gold coolant.
If you can get to your thermostat easy, this method has worked the best for me. Take the thermostat out, reinstall the thermostat housing. The drain the rad and refill with distilled. Drain rad again - repeat a few times until the fluid runs clear.
With the stat out, you don't have to wait till it comes to operating temp to get full flow through the system.
I'm actually a bad bad man because I do this method with the garden hose (not distilled). I just jam the hose in the rad with the drain cock open and run the engine for a few minutes until the fluid runs clear. Then top off with 100% coolent at 50% of the total cooling system capacity and top off the rest with distilled water.
