I changed the transfer case fluid on my 2014 Durango V6 model and it was pretty dark but didn't smell burnt, I was a little surprised to see that. I was running Redline D4 ATF and it only had 15,000 miles on it. I did put it thru some stress though, had a 2,000 mile trip with much of it on 80mph speed limit so I was going faster than that and it was about 95 degrees out. There was also a couple 10,000 ft summit climbs and I let the cruise control hold its speed so the rpms were running high for extended periods.
The transfer case is a MP 3010 single speed and only holds 1/2 quart. The manual says to change it every 120,000 with Shell ATF. The V8 model with a different T case says to use ATF+4. Think I'll stick with every 20,000 to 30,000 under normal duty since it's so cheap and easy to do.
