This was on my 2017 Subaru Impreza for 5 months and 5691 miles. No oil burned or added, car has 64,781 when filter was removed. This filter could have easily gone another run
Shoot, I knew I forgot something! It's an e-core. I just went back out and took these...Looks great. What was the inside like? Steel tube with louvers? E-core?
View attachment 139042View attachment 139043
5/12/21 but I bought this 6pk in March '22, I use them on my moms Accord too.Big window Ecore, no less! Is the date code still visible if you have the can? Just wondering how old the RA stock on these are...
Is it a PH2867XL? Just curious if it's newer than this one, maybe it's another in the line of untold construction changes...?The one for my Honda has the louvers and I'm scared to run it because they look like they're not opened well. I would absolutely run The ecore versions.
Yes that's the filter part number. I purchased it from Amazon back at the end of August of last year. I don't know exactly when the filter was manufactured.Is it a PH2867XL? Just curious if it's newer than this one, maybe it's another in the line of untold construction changes...?
Obviously, without seeing the louvers I can't confirm or dispute your observation. That said, based on my experience with many equivalent 7317 application filters using louvers, and observation multiple post use anecdotes of same here, I'll 'speculate' the louvers are fine. Meaning they are functional. Because of size, 7317 'uncut' best seen with extra light, keeping in mind that louvers open in two directions, so only half seen down tube. Also, that always more louver openings than holes over same tube area.The one for my Honda has the louvers and I'm scared to run it because they look like they're not opened well.....
Here's a peek down the center tube without dismantling the filterObviously, without seeing the louvers I can't confirm or dispute your observation. That said, based on my experience with many equivalent 7317 application filters using louvers, and observation multiple post use anecdotes of same here, I'll 'speculate' the louvers are fine. Meaning they are functional. Because of size, 7317 'uncut' best seen with extra light, keeping in mind that louvers open in two directions, so only half seen down tube. Also, that always more louver openings than holes over same tube area.
But, if you are still concerned about the louvers and won't run it, then do a c&p. Cut the media off, with or without endcaps off and post pics of tube. A pic with light down tube in darkened background would be excellent. Be interesting to see if your uncut filter louvers observation confirmed with media removed. My .02
Those look fine, I would have no issues running that filter. Keep in mind there are opposing rows of louvers.Here's a peek down the center tube without dismantling the filter View attachment 139609View attachment 139610
Only that one row that's close to the baseplate are a bit closed, but all the others look pretty good. I'd run it.Here's a peek down the center tube without dismantling the filter View attachment 139609View attachment 139610
Those louvers look fine to me, I'd run it with no worries.Here's a peek down the center tube without dismantling the filter....
( pics removed)
