A Husqvarna 435 is fine for the limbing and small trees. For the bigger a minimum Husqvarna would be a 550XP Mk 2, or for Echo, a 620 which is a great, torquey pro saw which can run a 24 in bar if needed
Good catch. I meant to say Husky 235. Gutless!A Husqvarna 435 is fine for the limbing and small trees. For the bigger a minimum Husqvarna would be a 550XP Mk 2, or for Echo, a 620 which is a great, torquey pro saw which can run a 24 in bar if needed
I was very happy with my Stihl Farm Boss even though it would not run on regular gas. The amount of gas a chainsaw uses in insignificant, so who cares. I am too old to play with chainsaws, so I gave it to my oldest son.
Bummer. Around my house Ace and a couple of local places are really reasonableMy issue is the dealer's here are absolute ripoff con artists. I don't have 2024 ~ 2025 examples but they like to charge full MSRP list + 15% mark up. Makes it impossible to maintain your equipment this way and they want you to "take it to them for service".
Best example is I had a commercial string trimmer and the stihl carb kit was $80. A whole carb was $249, and it was just proprietary enough that it was not possible to use an aftermarket kit.
The goal is to pick a chainsaw for the purpose of felling, and cutting up to use for firewood. Has existing residential Husky 435 that can be used for de-limbing.
Torn between 50cc or 60cc.
Torn between 18" bar vs 20" bar.
No stihl, just husky and echo.
Exactly what I did.When you say regular gas do you mean 87 octane? My Stihl recommends 89 minimum, and I use 91 E0.
Just my $0.02
How old is he? Since he's got the small saw already, I'd recommend a pro saw 60-70cc, and it should go for decades. My 372xp is from 2002, and cuts my firewood every year, and doesn't seem to be losing much performance at all.Have a friend that aquired a new 20+ acre fully wooded property. Has a blend of oak, some pine and spuce, a few beach, birch, red maple, and im sure other varietys native to Erie, PA. Good news is the pine trees are not plentiful. What I noticed is the way the land is, all trees are small diameter trunks with 12" to 18" diameter but are very tall starting at 30 upwards of 50 feet. Trees are very dense.
Then for the money and time, a 70cc class saw would be ideal. Husky 572 or Echo 7310. The Husky will be a bit lighter and peppier.So the primary function of the say is wood processing for the purpose of heating. Felling I would say is a secondary function. Drop the tree, then process it complete. To be clear it will be a selective game so that the whole forest is not logged out quickly. I would say 2-4 trees per season would be good and whatever falls will be a bonus.
This is great advice. I myself will not fall a tree, it needs to be on the ground already. In person I witnessed some widow makers detach from way above and came stabbing into the ground as soon as the trunk began to break loose. I was so frustrated waiting all summer for the tree guy to come, I was mere days from trying it myself. Had I done that, I would be dead.I have a Husky that has been good. Not sure what model.
If he is going to be doing work with a chainsaw he should familiarize himself with the hazards of chain sawing. You could get into trouble in a split second. A neighbor of mine lost his life as a result of chainsawing. There are some excellent eye opening videos out there about safety. There was one from I think the forestry department of Arizona that taught me a lot. I had been using a chainsaw off and on for years and was apparently doing a lot of dumb things. Lucky I came out OK.
I guess for a few 18" trees a year, any decent 50cc saw will do that. A 30"+ hardwood will be no fun with that saw though! There must be some bigger trees in the fence rows? I kind of like the 70cc saw as its not that heavy, but it can do the work and cut up nearly any tree in the east.This is great advice. I myself will not fall a tree, it needs to be on the ground already. In person I witnessed some widow makers detach from way above and came stabbing into the ground as soon as the trunk began to break loose. I was so frustrated waiting all summer for the tree guy to come, I was mere days from trying it myself. Had I done that, I would be dead.
He knew better, spotted what I didn't, and tied the tree off, cut the trunk, then walked 30 feet and gave it a pull.
So we have moved away from 50cc class and now into the 60 and 70cc class? Interesting.
Fordiesel69, check out your Pennsylvania DNR, USDA Forest Service/NRCS, and Penn State Forestry Extension to learn about (maybe) free services to have someone develop a forest stand prescription for you (dumbed down management plan) .To be clear it will be a selective game so that the whole forest is not logged out quickly. I would say 2-4 trees per season would be good and whatever falls will be a bonus.
