Stihl chainsaw running full on in a cut. The stupid spark plug wire falls off. Now no spark. Have not checked anything yet, but thinking the coil is damaged by arc over.
+1Your plug wire has come loose. Reattach everything properly and it will run. Coils don't fail just because a plug wire became detached.
Stihl is a good saw when they are running. I have a 250 and 390. Some of these coils have a spike sticking out and it stabs into the plug wire. You can use any old plug wire cut to length. If you use a screwdriver in the end or bolt etc held above the frame make sure you give it a hard pull or you wont see any spark. Good luck.It has fallen off a few other times with no problem plugging back on and starting. This time no go. How can it be a bad spark plug it was running top notch before this deal? Yeah unobtainium stihl ignition module, that is why I had to use one of those little after market ones years ago, it worked just great till now. I'll dig into it when I can. I should have dealt with the bad fit on the plug in the first place, it would have been less work and likely cheaper.
Yup, Stihl is pretty low on my list to own, both for their current quality and parts availability. Some of the older parts they do have are so expensive you could buy a new piece of equipment for the price. It's sad because they used to make awesome stuff.So you already replaced the coil with an aftermarket becuase the stihl was unavail, or too expensive?
This is one reason why stihl is my #3 pick for ownership. #1 - Echo, #2 - Husqvarna, #3 - Stihl. Echo has started obsoleting stuff from the 1980's and into maybe the mid 90s on certain products, husky gives you about 15-20 yrs tops before stuff becomes obsolete, but it usually is not a high failure part, however stihl really sticks it to their owners hard. They made some really awsome products only to intentionally obsolete a very critical failure part. Quite often after just 10 yrs. I do not support those types of companies with my money. An ignition coil should never become obsolete.
I had a customer push mower with that issue. Every time you went over a bump the plug wire fell out just enough to not make contact and the mower would shut off. I love telling customers it was a no parts required fix.Granted it was my yard machines push mower but I had to ever so slightly squeeze the boot and metal piece inside to get it to attach tightly to the sparkplug.
When the wire falls off the transistor switch sees a voltage spike,. I am using power of tens for easy arthmetic, the actuall raitos and ovoltages are different. If the coil has a 100 to one turns ratio, if the plug takes 10K to fire the transistor sees 1000 volts. If the wire falls off, it sees much more voltage than normal If the protection circuits fail it can kill or reduce the life of the ignition. This does happen. Aftermarket GM ingition modules used to be touchy,Your plug wire has come loose. Reattach everything properly and it will run. Coils don't fail just because a plug wire became detached.
