Chain lube reformulated?
West Michigan
When did the Liquid Wrench Chain & Cable lube get reformulated? I've been using a stash up for the past couple years and its been working great. Probably the best chain lube I'd used to date. Lasts for hundreds of miles (in dry conditions) and I have literally no chain wear on my 10spd Sram chain. The cans I've been using state they contain "synthetic moly" but if you look at the new product specs they moved to "Cerflon." Isn't the cerflon their propriety PTFE additive? If so, this is a real disappointment. Any suggestions for a lube similar to the old version? It sprayed on clear/tan and dried clear. I've used Boeshield T9 in the past but it doesn't work nearly as well. Maybe Cyclo chain & cable or Amsoil HDMP?
Link to the Liquid Wrench description
