Cavalier vs. OReilly's
Nothern USA
I recently did a relatively extensive brake job on my 02 Cavalier. It has about 135K on it, mostly open 2 lane. This was the second set of pads I installed. The first may have gone longer if hadn't cut corners on the hardware. This time, I tried to do everything I should, pads, new caliper bushings, rebuilt the calipers, and cleaned everything up good and coated everything with Sil-Glyde. In the back it was new shoes, springs, adjusters, rebuilt the cylinders, and again Sil-glyde. I put a little antisieze on all the contact surfaces and the wheel studs, torquing them to 80 pound feet.
I had a terrible time in the back. OReilly's sold me the wrong hardware kit and wheel cylinder kits. I never did find anybody that had a kit with the clips that hold the shoes to the backing plate. I ended up reusing the old ones. Anyhow, I eventually got everything back together and the brakes bled. No matter what I did, I had a low brake pedal, not spongy, needing bled, just almost to the floor, then solid. I finally pulled one caliper off and put a block of wood in it and had my wife work the brakes while I watched. Each time she let off the pedal, the piston pulled back into the caliper. ???????????? I messed around and messed around. I don't think I could have made a hard stop to save my life.
Finally I went NAPA and bought 2 more caliper kits. I pulled the calipers off today and replaced the seals and o-rings. The old o-rings were clearly slightly too large, just enough to keep the piston from sliding freely as it must. After bleeding the brakes, I had the nice, high, solid pedal I have always had after a brake job.
??????????? Are Oreilly's a bunch of doofuses or is GM not building any 2 Cavaliers alike? Mine is an early LX model with the Ecotec and a 5 speed. I like to do preventative hydraulic rebuilds to avoid problems later.
I think you can only get so much help out of any one wife. By being sparing about it, I have managed to keep the same one for 40 years. She did get a break while our son was at home.
probably a combination of both. on the 01 (2.2L OHV) cavalier my wife has apparently in 99 or something Gm slightly revised the dimensions of the intake box requiring a different sized filter. Unforunately most if not all brands are for the old box. Nothing a piece of plastic and some screws couldn't fix.
Same with the 04 sierra of my dad's. Some design change on the pan requiring the filter to had a diagonal cut corner instead of it coming to a point. Autostore filters do not have it. Ended up getting correct one from my Gm parts supplier at the time.
GM does not build two Cavalier alike. There can be two different brake drum/shoe sizes for the rear. They build some for export with a larger rear brake but have been known to cycle these into domestic bound production cars. The drums, shoes, hardware kit and brake cylinders for the rear can be different. Unless you know exactly what you have, the parts house bozo behind the counter will just give what comes up on the computer and maybe 50/50 at best correct.
Hootbro
Hootbro
Even if you personally know what you have, the listings in the computer often have inexplicable descriptions of different options and features which make it almost impossible for even the car's owner to decipher what is appropriate. The parts guy is helpless under those circumstances.
Yeah, I think there is 200 and 225 mm rear drums or something similar. I got asked at vatozone when I did the rears on my old cavi. I knew what I had and I got the right parts.
