CATERHAM blend --Mobil 0W40 SM/TGMO 0W20 SN
Ontario, Canada
Here is a VOA of the CATERHAM blend I'm using at the moment in my Sonata 2.4L Limited.
CATERHAM blend : TGMO/ Mobil 0W40-(60/40)
Mobil 0W40 SM
TGMO 0W20 SN
Oil mileage----0 km
Aluminum------2PPM
Chromium------0
Iron------------1
Copper---------0
Lead-----------0
Tin------------0
Moly----------81
Nickel---------0
Manganese-----0
Silver----------0
Titanium-------0
Potassium------3
Boron----------69
Silicon---------3
Sodium---------5
Calcium--------2313
Magnesium------19
Phosphorus-----681
Zinc-----------813
Barium---------1
SUS Viscosity @ 210f---N/A
Sulf (UFM#)----------28
Oxidation(UFM#)-----28
Nitr (UFM#)---------7
cst @ 100c ------10.37
Flashpoint----NEG
Fuel%------NEG
Water------NEG
Antifreeze---NEG
Insolubles-----.2
TBN----------not tested
ISO Code-----17/12
06Micron per ml----986
14Micron per ml----39
Even given that BOTH are using the Infineum tri-nuclear moly, I would have thought it would be at least slightly higher than that, as well as a little bit higher ZDDP ppm, given how high the M1 brew is in that compound.
