Hi there
it seems that wife's Suzuki Vitara 1.0 Boosterjet with 129000 km finally has carbon buildup into CAT+DPF (built into turbo downpipe) preventing the engine to flow correctly, causing low power at low revs and a reduced peak power. I get a P24A4 code if I floor it, and I can make it go away driving enough or doing a good italian tune-up, and get back some of the lost power, but it's still missing like 20hp.
I'd like to try feeding paint thinner into the fuel tank as this method helped me clean cats in the past, but that was on indiject injection engines.
Also, what kind of thinner would you recommend ?
-white spirit ?
-cellulose (lacquer) thinner ?
-anything else raw? turpentine, acetone, naphtha, toluene, xylene?
I want to try it before removing the cat to wash it with detergent. Any advice appreciated
Thanks
-white spirit ?
