CAT 3126, Schaeffer 7k 15W-40, 165 hrs (2 years)
Hermon, ME
Here's another for you, Jim Allen!
Caterpillar 3126, fire engine service
First run on Schaeffer's Supreme 7000 15w40 CJ-4
1080 hrs on unit, 165 hrs and 2 years on oil.
Napa Gold oil filter
No make up oil.
Analysis by Polaris Labs
Code:
Current test 104 hrs New oil
Fe 13 7 1
Cr 0 0 0
Ni 0 0 0
Al 0 1 0
Cu 1 1 0
Pb 0 0 0
Sn 0 0 0
Cd 0 0 0
Ag 0 0 0
V 0 0 0
Si 5 8 16
Na 6 5 9
K 0 0 0
Ti 0 0 0
Mo 331 272 360
Sb 285 258 350
Mn 0 0 0
Li 0 0 0
B 4 4 1
Mg 792 642 862
Ca 1393 1181 1349
Ba 0 0 1
P 1043 895 1223
Z 1241 1069 1417
Fuel
Soot 0.4%
Water
Visc. @ 100C
14.1 14.2 15.6
TAN 2.89 2.65 3.00
TBN 6.35 8.63 9.39
OX 8 9 8
NIT 11 11 10
Heading into year 3!
Thanks,
REDDOG
Love to see these extended OCIs!
Why not continue to use it? Look at the numbers. Still a viable fluid, that's for sure. Add-pack decent; contamination low; vis in good shape. What's not to like?
Yet MORE evidence that oil has no idea of how old it is ...
Oil and filter are still in service and I'll retest at the 3 year mark to see where we are. The duty profile for this engine has changed-it is now a second engine for fire calls but still primary rescue for tools, jaws, etc.. It will probably accumulate 50-60 hrs a year from now on, I'm guessing.
As far as variances go given the spread of time between these samples I would expect some variances especially in the additive metals which tend to be less repeatable anyway. Wear metals have a much tighter trend. I'm comfortable leaving the oil in.
Thanks, REDDOG
Thanks REDDOG! I'll add it to my evidence locker. Are you gonna try for four if three is OK? I had to shut down mine at three due to soot but with better filtration, I might have tried for more. This is an especially awesome result considering there was no makeup oil. My three year had several makeup quarts... but then it's a tired (8300 hour) tractor that was (previously) neglected and lives in a barn.
As long as everything looks good I'll keep it in service. Even at the 4 year mark it would probably have between 250 and 300 hrs on it.
Also, though this is a bit OT, I'd sure like to have more of these 2003 era CAT engines! This has been a great unit and I honestly hate all the emissions crud on the newer diesels.
