VOA on Castrol TWS 10w-60, API SJ. This is the oil “co-engineered” by BMW and Castrol (according to the label) for BMW late model M engines (M3, M5, M6). The bottle bears what appears to be a date code of 02.06.08 and says the oil was manufactured in the EU.
Elements and properties that were zero or null are not listed. No TBN was checked.
Aluminum 2 ppm
Iron 1 ppm
Molybednum 2 ppm
Boron 109 ppm
Silicon 4 ppm
Sodium 1 ppm
Calcium 1141 ppm
Magnesium 470 ppm
Phosphorous 641 ppm
Zinc 796 ppm
SUS vis @ 210F 109.8
cSt vis @ 100C 22.64
Flashpoint 460F
BLACKSTONE COMMENTS:
This sample of virgin 10w-60 oil had normal viscosity. No moisture was found and only a trace of wear metals was present in the sample. That is becoming more of a common find in new oil. The dominant additive is calcium, which is a detergent/dispersive additive. Phosphorous and zinc are anti-wear additives. Silicon at 4 ppm is present to prevent foaming. This oil is in serviceable condition and should work well for your engine.
Aluminum 2 ppm
Iron 1 ppm
Molybednum 2 ppm
Boron 109 ppm
Silicon 4 ppm
Sodium 1 ppm
Calcium 1141 ppm
Magnesium 470 ppm
Phosphorous 641 ppm
Zinc 796 ppm
Flashpoint 460F
