P PE400 Joined Oct 21, 2011 Messages 99 Location MA Jun 10, 2015 #1 We use this at work. This has truned out to be a good fit for our shop. Any info on it here?
P PE400 Thread starter Joined Oct 21, 2011 Messages 99 Location MA Jun 10, 2015 #2 http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/F7023ECA3A086ECB80257CBD003FD086/$File/BPXE-9JD3PQ.pdf
B brslds Joined Oct 13, 2014 Messages 114 Location US Jun 10, 2015 #3 What applications do you guys use the grease for?
P PE400 Thread starter Joined Oct 21, 2011 Messages 99 Location MA Jun 15, 2015 #4 It is our go to grease 110lb keg. packing wheel bearings, every zerk its a #2 high temp with good water resistance. heavy vehicles ect.
R robo339 Joined Mar 1, 2015 Messages 726 Location huntsville tx Jun 18, 2015 #5 I use it in a 2007 d5lgp caterpillar dozer all pivot joints, pins, and track tensioners very good grease
U UrS4 Joined Jul 30, 2013 Messages 88 Location Denmark Jun 20, 2015 #6 Why do they only list SSU viscosity...? - is that the preferred method in the US? Converts to ISO 160, nlgi #1 and ISO 220, nlgi #2 The EP specs is looking good. I guess their solid additive is moly.. but if so, how much then?
