Castrol Edge 5W-50 UOA after 4 hours on the track in a Mustang GT
Longtime lurker, first time poster. Thought you folks might be interested in some of the oil testing I’ve been doing with my 2019 Mustang GT. I’ve done a series of long drain interval, ~10k miles, tests using various 5W-20 oils but that info is going to take some time to put together so I figured I’d start off with what I’m currently into. Seeing how well oils and my engine hold up to HPDE track use. Diff and trans oil too but I haven’t sent that stuff out for analysis yet.
The Setup
Car: 2019 Mustang GT PP2
Oil: 10 quarts Castrol Edge 5W-50, API SP
Use: 30 min sessions, 4 hours total time on track time, 1 hour was wet where the oil wasn’t significantly heated, ~250 total miles.
Ambient temp: High 40s low 50s F
Baseline Oil Temp: 200-205 F
Peak Oil Temp: 260-265 F during the dry sessions, ~220 F during the wet
My Mustang didn’t come with a real oil temp gauge, so these values are from a sensor I installed in an oil filter sandwich plate. All samples were sucked out through the dipstick tube.
Oil info from Castrol
KV @ 100C: 16.7
HTHS @ 150C: 4 (not on the product sheet but that’s the value they told me when I asked, which is a far better response than “sorry we can’t say” from Mobil 1 and Pennzoil)
VI: 177
Problems
It was freezing outside while I was prepping my car and the old oil filter wasn’t budging. I wasn't in the mood to dig out my oil filter wrench so I left it on meaning the new Castrol was contaminated with around 1/2-1 quart of Motul 8100 EcoLite 5W-20 with ~3000 miles of use.
Results
Right off the bat the oil is out of grade but I’m sure the Motul contamination is significantly contributing to that. The kv100 viscosity and oxidation values pre and post track are unchanged so this stuff really wasn't bothered by having some heat put into it.
The lab flagged the titanium value 18 ppm but that’s just part of Castrol Edge formulation. When I ran Edge 5W-20 my titanium values were up at 17 ppm.
Iron wear is about what I’d see from 2000 miles of daily driving with 5w-20. 3 ppm of lead raises an eyebrow since I’ve never seen lead show up before, even from the UOA on my factory break in oil when wear metals were through the roof. I also didn’t fill up with gas at the track which I’ve heard can sometimes cause a little lead contamination. Possibly a sign of bearing wear, possibly just a fluke from some contamination during sampling. We’ll have to see if that’s a consistent thing that shows up from track use.
What really surprised me was how much ZDDP was in this oil. I don’t think Castrol advertises it anywhere but this stuff really has some zinc in for an API SP oil, 1169 ppm phosphorus 1386 ppm zinc. Thats close to what Valvoline advertises in their high zinc VR1 racing oil.
~770 ppm phosphorus and ~870 ppm zinc were my average values when previously running Castrol Edge 5W-20, which is also right in line with values I saw when using Mobil 1, Valvoline, and Motorcraft.
Conclusions
Again I’m amazed Castrol doesn't advertise the ZDDP in this oil, I’m not complaining but you’d think it would be a selling point. I’m also impressed the viscosity and oxidation didn’t budge. I’ll definitely run this stuff again down the road once the weather gets warmer and with the old oil fully drained out.
You used it x4 more this sample than last with only x2 the wear. Nice! Also, These oils have higher allowable limits on their additives & not inline with many current or past emissions compliance. Thanks for sharing.
2 ppm vs 4 ppm is experimental error. I wouldn't look into values that small for Fe.
The lead is different because its not supposed to be there.
Why not run 5,000 miles?
The recommended oci for track use is 4 hours, just a smidge lower than the 10k mile intervals I was doing while daily driving. Now I’m a real track novice and wasn’t pushing my car anywhere close to its limit, but I did put a fair amount of sustained heat into the oil and it was reassuring to see that the oil was unbothered by the whole affair.
Also for how much it costs to spend a weekend at the track, treating the oil as a one and done consumable really doesn’t up the total cost very much.
Is that recommendation 5W50?
I used Castrol 0W40, Pennzoil Platinum Euro 5W40, Motul X-Cess 5W40 on track more than 4hrs and 5k OCI and no any more wear than regular 5K OCI. That is in BMW.
The recommendations vary. For my PP2 and the Mach 1 the official Ford rec is 5w-30 every 4 hours. GT350 its 5w-50 with no special interval stated for track use, so I guess it’s just the general severe use 3-5k mile interval. GT500 it’s 5w-50 every 4 hours.
Move over to Ford Performance and every V8 rec regardless of engine going back to the S197 cars is 5w-50 every 4 hours.
My plan is to change it after every track weekend, play around with different oils and see if any of them standout out in a good or bad way.
Nothing in UOA says you should change the oil after 4hrs.
I am wondering if FORD thinks that people will go with the cheapest thing they can find, so they are being cautious.
I think they’re also assuming theres an expert driver at the wheel. My test here was about as soft as you could possibly get. Novice track driver, cool day, track with a technical section that really slows things down before you get back in the throttle. I’m sure as those things change the oil won’t come back looking quite as perfect.
In terms of oil quality this is actually one of the cheapest 50 weight oils you can get. NAPA’s had it on sale for $6/quart, plus a rebate from Castrol last year brought it down even further. This summer I’m planning on trying Mobil 1 15W-50, about $5.60 a quart at Walmart, and Valvoline VR1 20W-50 which is also around $6/quart.
I would close the viscosity gap and go with M1 15-50 vs 5-50 Castrol
Yeah I have a few jugs of that to try out this summer in the warmer weather along with some Valvoline VR1 20w-50.
I got a chance to talk with an engine guy from Ford Performance and he pointed out there’s no lead in the bearings and he couldn’t think of any spot where there would be lead in the engine so the few ppm must have been contamination during sampling.
