Our home has a brick chimney with two flues for two wood burning fireplaces that are no longer used. I keep the lower dampers shut but was thinking of covering the top outlets to prevent cold air/pests from entering the chimney. Eventually, the fireplaces will be covered with insulation/drywall/etc.
My chimney looks similar to this and is on an exterior wall:
Based on this article from Fine Home Building, I was just going to place a 2x8x16 stone patio paver over each outlet and call it good. They also mention a chimney balloon but I don't think I will bother with that.
But upon further research, I see some people claiming that the unused chimney still needs ventilation and that air bricks should be installed to prevent condensation? Eg:
https://www.mybuilder.com/questions/v/52483/how-to-ventilate-and-insulate-a-capped-chimney
https://www.diynot.com/diy/threads/sealing-a-capped-flue-without-any-airbricks.160312/
Any experience or input on this? If true, then I'd rather not create more issues and leave the top of the chimney open.
