Our LG refrigerator recently died. We could hear a clicking sound coming from the kitchen in the prior 1-2 weeks but I never pinpointed where it was coming from but our son said it was coming from the fridge. Anyway, the other morning I opened it up and no light inside. First thought was the bulb just burned out but no light in the freezer side either. Finally, the front panel lights were out as well.I pulled the fuse on the control board and it appears to have burned up but before I simply swap in a new fuse, I know "something caused it to blow". Could have just been a surge but apparently the clicking sound is a symptom of a failing capacitor.
I've pulled both the 'motor starting capacitor' and 'motor running sh capacitor' and testing with my multimeter on the continuity check indicates both capacitor's circuits are "open". Now, on the 'motor running sh capacitor', if I let it sit for a bit, when I first touch the terminals I get a short tone but then it stops. Immediately checking again shows it being open. Using the Ohm reading, I get no value.
Is it common for both to fail at the same time ?
