At the end of summer/early fall, I picked up an old snowblower with a Tecumseh HM-80 engine (4 cycle L head). It was a neglected machine, but I got it cheap, and the engine ran. It took a few tries to get it going, but it would fire up fine. I already cleaned out the engine with several oil changes, and it now has GC in it. It is also sporting a new spark plug (old one was actually different than spec, but wasn't anything more than normally worn).
Now that it's winter, it won't start. First issue seems to be the recoil mechanism. It won't rewind fully, so I can't ever get enough rope to pull to start it successfully. I took that part off this evening, and tried what is called a drill start (look it up on Youtube). The drills I tried weren't the most powerful around, and I also didn't spend too much time trying the start, but it still won't go. Relatively mild today - 0C/32F. When doing this, the engine sounds like it's sputtering, almost firing when I turn it, but it never really catches.
I plan on fixing the non rewinding recoil and trying that (but may not have luck starting I suspect).
Where do I try my search for the problem next? (Fuel is fresh and with stabilizer added)
