Can't align text
Australia
Hi guys,
I tried posting my used oil analysis however no matter what I try and do the forum ignores the spacing between the text and value and posts it with a single space.
e.g.:
Lead 42
Iron 13
Aluminum 3
Copper 6
How can I get it to align like a table to make it easy to read?
Additionally adding a picture to a post does nothing either.
Put [ code ] [ /code ] tags around the block of text that you want aligned. Just remove the spaces between the parentheses and the word code - I had to add them so that the tags would be visible in my post.
Example:
Code
Lead 42
Iron 13
Aluminum 3
Copper 6
You can click "Quote" on my post, and you will see what it should look like when you type it up.
I fill the space with dots to make them line up.
e.g.:
Lead.............42
Iron...............13
Aluminum.......3
Copper...........6
Quattro Pete's method is more elegant.
