Couple of other things.
1. Users of straight Vegetable Oil (SVO) as diesel fuel have some indirect and accidental experience with this, especially if they get fuel dilution of the sump oil. There are a few failure modes associated with this, including:-
(a) The sump oil gels, and the engine dies from lack of lubrication. That's your main risk, but you'll get there quicker because you've replaced most of your sump oil with veg.
(b) The veg oil sticks the piston rings, which allow enough lube oil into the cylinders to run the engine which races uncontrollably until it breaks, or uses up all its sump oil, when it breaks.
Can only be stopped by cutting of its air supply, (or, I suppose, shooting it, if you are in the USA and prepared for the zombie apocalypse). I don't think this can happen with a petrol engine.
(c) Chunks of carbon go through the exhaust valves and hit the turbo blades. Only applies if you (used to) have turbo blades.
2. Having looked at your emissions numbers which I skipped before, it appears you only failed on NOX. I can't think of a likely way that using veg oil as a lube will reduce NOX. IF it reduces oil burning I suppose the efficiency of the catalyst MIGHT go up, but its a bit of a stretch. I THINK NOX is reduced at source by reducing combustion temperatures, for example using EGR. If you could get some water into your fuel, perhaps by using alcohol as a bridging solvent, or rigging up some kind of dripper/squirter in the induction path, that might have some cooling effect.
