Vw temp sensors had a high failure rate,I know I had one of them.
That is strange.
Garak said:It just calls for phosphate free, which is more of a European issue than a North American issue due to water quality.
Phosphates are a water pollutant. That is why, for example, European detergents and coolant, commonly do not contain phosphates. Phosphates promote algae growth. That's why also regions in the USA, for example, Washington State, have banned detergents containing phosphates.
Originally Posted By: Garak
I only use RO water, in any event. If Audi or VW wishes to specify a proprietary coolant that only they sell, they can provide that for free for their American customers, as per American law.
Pentosin is not a VAG product. It is commonly available online, and in metropolitan areas.
No, I wouldn't do just the timing belt. The timing belt is $20, the accessory belt is $8, the thermostat is about $15 (O-ring included). RTV sealant is cheap. If one is doing it oneself, the costliest item in this repair is the coolant, if one goes for Pentosin. If one goes for Dex-Cool, the coolant costs are far less.
You left out a goo part of the parts that should be replaced when the TB job is done. The least expensive TB kits from places like ECS Tuning and Blauparts are around $200.
The point being, however, that just because one pays a premium price for a car does not mean one need pay a premium price for all parts and consumables.
So "perception" is okay when it comes to buying the car, but not when buying OEM fluids?
An Audi costs more, because one has, at least, a perception of getting a little more for one's money.
But springing for OEM fluids will not do the same? You cannot really have it both ways now, can you?
Few will compare an A8 to a Focus. Is Pentosin better than Dex-Cool?
Does Pentosin meet Ford specs?
Perhaps, but it's just as likely that they are close to identical. Is it worth the price premium? Not likely.
Faith-base decision-making when it comes to car maintenance is a personal matter.
When one looks at Ford, I cannot justify buying G-05 from a Ford dealership, when it's Zerex G-05 at double the price of the Zerex bottle.
So Ford marks up the identical product. I am glad VW does not the same thing.
I'm not sure, and it really doesn't matter to me one way or another.
It matters because you said that there's a "Pentosin label on a bottle of dexcool." That's possible only if Zerex produces in Germany.
That depends upon where one lives. I would suggest that Pentosin isn't readily available to everyone in the U.S. It might be reasonably available in big cities, both in Canada and the U.S., but I would suggest that getting Pentosin in Minot, ND, would be a lot harder than getting it in Toronto, ON. In a place like Minot or Regina, one is quite likely stuck with an online distributor (if one wants a good price and has patience) or an Audi/VW dealer if one wants to pay the premium but get it in a hurry.
One has to hope that out in the boonies no more pressing car trouble happens than one coolant change every 5 years.
I'd gladly use Pentosin if I could readily get it. Last time I tried to order it, my supplier had 1 bottle. They now have zero.
That last bottle may pop up on Ebay!
And until Pentosin is more readily available and available at a more reasonable price, I'm going to stick with dexclones.
I still do not understand how Canada's supply issues affect Dan.
Oddly enough, a nearby Ford dealership is using dexclones for their service, even on unsealed cooling systems, instead of their factory recommended G-05. I don't think a dexclone is the best option for an unsealed cooling system. In my sealed cooling system, I'm not worried.
Most sealed coolant systems become eventually unsealed, usually due to lack of preventive maintenance, and aeration will quickly become an issue.
Cheers,
-J
