Can you compare Mobil 1 5w-30 EP to Mobil1 5w-30 ESP?
NJ
So as the title indicates, can you compare the Mobil 1 5w30 EP and ESP oils? Is there a clear winner or "better" of the two? Is it attempting to comparing apples and oranges? If there is a "winner", if the difference marginal ? The price point of both oils is basically the same, so that part is removed from the equation.
Thank you!
Thank you!
Yes if you spend thousands on engine testing and tear down.
