Can someone explain to me the nomenclature of ammo
Originally Posted By: hatt
Pretty clear I said 1000 yards when you replied to me. You even put it in bold.
Yes I did. My reply was in regard to COST, NOT RANGE. Shooting competitively with the 6.5 is not going to be any "cheaper", (what you were claiming in your post), than the larger calibers, with all things considered. This regardless if the range is 1,000 yards with a 6.5, or the same or greater with longer range calibers. Your biggest problem is staying on track, as well as comprehending the written word. Try reading a little slower. Then think about what you've just read. You'll have much better luck, trust me.
6.5 guns and ammo are generally cheaper than 300 and up. Facts are facts. Not everyone is a big budget competition shooter. 6.5 much lower cost of entry for people wanting to mess around on the weekends. Plus can be used for hunting a lot easier than your LM or BMG. People that don't care about budget still go for 6mm and 6.5mm vs the field while you're touting the field. You're not right on anything.
Facts are facts.
Yes they are. Your problem, (and this is getting to be an old story), is you're confusing "facts" with your opinion. This isn't about me being"right". It's all about you proving your total ignorance on the subject, as well as your complete inability to comprehend. As I said, if you spent as much time actually doing, as you sit here preaching about what you don't know, you would see this as clearly as I and others do.
I don't think you can argue 6.5 being cheaper than .308 (included in your 300 and up). Yes, it is definitely cheaper than .338LM, but even .300WM is pretty cheap, and rifles chambered in the "old school" cartridges like .308, .300WM....etc are more plentiful and generally cheaper. That is unless we are exclusively looking at rifles like the Ruger Precision or something along those lines.
Look at the Remington 700 for example:
https://www.remington.com/rifles/bolt-action/model-700/model-700-sps-stainless
I don't see any metric cartridges on the list, though of course the .260 is there (which gets lumped in with the 6.5) but no CM, Lapua or others. And of course the 700 family is the base for most precision rifle builds.
I don't think you can argue 6.5 being cheaper than .308 (included in your 300 and up). Yes, it is definitely cheaper than .338LM, but even .300WM is pretty cheap, and rifles chambered in the "old school" cartridges like .308, .300WM....etc are more plentiful and generally cheaper.........
Correct. I can purchase .300 Win. Mag brass cheaper than any or all the 6.5 brass. I say this because I've done it. Not once, but many times. Even .50 BMG brass can be had cheaper, because it's a military round like the .308, and brass is plentiful. Also these larger capacity cartridges utilize military surplus powders very effectively like WC-872. (This powder is effective in all of the .338 bores as well).
This powder is far cheaper than anything required for shooting the 6.5's. Especially when purchased in quantity from places like Jeff Bartlett and Pat's Reloading. It's even cheaper if you want to buy demilled pulldown powder of the same type. I've even gotten great buys on match bullets in both .30 and .50 caliber from them as well. Although they don't always carry them. 6.5 projectiles are far more expensive. The optics required to shoot successfully at that range are also the same. As are rings and MOA mounts. And also rifles, as you've pointed out. In short, if you want to shoot 1,000 yards with a 6.5, (you pick the flavor), you're not going to do it any cheaper when all is considered.
Not talking about .308. 300 normally refers to mags. In normal factory offerings short action non mags are usually cheaper than magnum guns. For custom and low production builders maybe not. It may not be 50% cheaper to shoot 6.5 vs .300 WM but it's going to cheaper.
*snip*
You said .300 and up and you didn't specify mags either, as you can see from the above quote.
Up here, .300WM is definitely cheaper than the 6.5 cartridges (other than .260 Remington) as you can buy the ammo anywhere (Canadian Tire, Walmart, Home Hardware..etc), whilst this is not the case for the 6.5's, which are rare and subsequently, unless you reload, extremely hard to come by. The same goes for the rifles, if we ignore the .260 Remington, they are no where near as available as the standard calibre stuff nor in the inexpensive configurations. I guarantee my local store has a number of .300WM and .300WSM in stock right at this moment, and I doubt they have a single 6.5.
It is just the reality of them being relatively new cartridges.
I can usually get, often on sale, Winchester White Box or Federal blue box in .308 or .300WM. The same cannot be said for a cartridge like 6.5CM.
As I said earlier, I completely understand the draw to these cartridges for PRS and the like, but the cost argument is pretty weak. Most of these guys have guns that cost even more than my CDX-33 and are hand loading using Lapua brass or similar as well as utilizing premium projectiles for consistent and reliable performance. That is not inexpensive. While i am relatively new to hand loading myself, and there is a reduced cost if you shop on price, I can still buy something like WWB for less than my reloads cost to make. Surplus ammo in .308 and the like is even cheaper.
Apparently I made the mistake of assuming "gun" people here would relate "300" to the numerous magnum rounds that use .300 So&So Magnum as the name and not the .308 Winchester or any other non mag that doesn't use 300(yes, I'm aware of the Savage and Blackout).
I can get .300 WM here at WM pretty cheap. But who's shooting Core-lokt or Powerpoints in extreme long range competitions? The places that have precision .300WM ammo also have various other 6.5 ammo. .300 is usually more expensive. Go to MidwayUSA or some other outfit and do apples to apples comparisons on premium target ammo. You can compare reloading components too. And why do you keep separating the .260? It's certainly a 6.5 and gets put into the list.
No one shoots factory ammunition in 1000 yard competition matches. Or even 600 yard Palma Matches. All handload. Something else you are showcasing your complete lack of knowledge of.
Why would you assume that? You said .300 and up and made no mention of magnums. If you wanted to reference specific cartridges, reference those cartridges, don't try to skate around it after the fact like you just expected us to "know" which rounds you were talking about. That's a ridiculous cop-out in an attempt to make up for your lack of being specific.
So we are now only talking about competitions? Because you stated:
I'm talking in general. And considering the above statement, I thought you were as well. When we start talking about reloading and expensive precision rifles for competition, the idea of cost becomes far less significant. I spent a great deal of money on my .338LM and related components, and yes, it is expensive to shoot. I reload for it because factory box ammo is ridiculous and limited in selection. I also have a precision .308 which gets fed pretty much whatever is on sale most of the time, particular when used for plinking, or as you put it above "messing around on weekends". This is something I can't do with a 6.5CM, as there is no comparably cheap ammo in that calibre. Are we on the same page yet?
I'm not trying to get involved in the [censored] match going on between you and billt460, as I think some of your points are perfectly valid and I believe I've indicated as such. But I AM beginning to feel the frustration here when you continue to move the goal posts around and expect us to infer things from what you've stated that support your position rather than taking them at face value.
Because it is a non-metric cartridge and much, MUCH older than 6.5CM and 6.5 Lapua. When people talk about the 6.5 in the precision groups I'm a member of, they are generally talking about the 6.5CM, as it was/is the "hot ticket" for quite a while and I believe the most popular 6.5 in PRS. If somebody wants to talk about one of the other cartridges like the 6.5 Lapua, they will specify as such. Hence, my points are all in the context of this cartridge and others like it. The 260 Remington is a well supported cartridge that happens to fall into the modern 6.5 family. I separate it for that reason. For clarity as to what I am speaking about specifically. I try not to be ambiguous because, as our conversation here has aptly demonstrated, being vague has its issues.
Put differently: the .260 Remington is the exception as it actually IS readily available, including in cheap box ammo, and inexpensive rifles are available in that calibre. This includes the Remington 700 family, the most common platform upon which precision rigs are built.
Why would you assume that? You said .300 and up and made no mention of magnums. If you wanted to reference specific cartridges, reference those cartridges, don't try to skate around it after the fact like you just expected us to "know" which rounds you were talking about. That's a ridiculous cop-out in an attempt to make up for your lack of being specific. Because it's assumed we'd be talking about magnums. What larger than 30 caliber none mags would be seriously considered in the conversation for extreme long range work?
I'm comparing apples to apples. The available ammo you're finding for low prices is hunting ammo. Not long range target ammo. Looking at online retailers confirms long range target 6.5 ammo is generally cheaper than long range target .300WM.
I'm talking in general. And considering the above statement, I thought you were as well. When we start talking about reloading and expensive precision rifles for competition, the idea of cost becomes far less significant. I spent a great deal of money on my .338LM and related components, and yes, it is expensive to shoot. I reload for it because factory box ammo is ridiculous and limited in selection. I also have a precision .308 which gets fed pretty much whatever is on sale most of the time, particular when used for plinking, or as you put it above "messing around on weekends". This is something I can't do with a 6.5CM, as there is no comparably cheap ammo in that calibre. Are we on the same page yet? Midway has match 6.5 CM for $23 and up a box. Deer rounds $18. Certainly within the reach of weekend warriors. And also cheaper than equivalent quality 300WM.
My responses in red.
We were talking about PRS, 6.5mm and 6mm, what calibre was used before those? Predominantly .308. In PRS I don't think the mags have ever had a presence. I think two topics are being conflated here, as you brought out PRS when you brought out the 6.5 and 6mm calibres, all of which max out at around the 1000 yard mark and that was one of the first posts of yours I responded to. Extreme long range is where the rifles that Bill brought up and you dismissed begin to shine, like my .338LM. So if we are talking about 6.5mm and 6mm and PRS then it is assumed we are also talking about .308. If we depart from your >.300 requirement then we would also be discussing .270, .245, .260....etc all non-magnum cartridges. But of course most of those have not been popular in PRS either.
Of course it is hunting ammo, that was one of the bloody things you mentioned in what I quoted!! Weekend plinking AND HUNTING!!!! If you wanted to exclusively talk about match ammo you should not have mentioned those, LOL!
However for competition/match, most people use hand loads, so then match ammo becomes less important. And my point about rifles and most being based on the 700 action/platform still stands, as it is not available in anything other than the .260 Remington and the other common non-metric calibres.
I am not trying to be rude here and am trying, in vain, to get us onto the same page. This is what I'm talking about when I said you are moving the goal posts around. You've touched on a myriad of subjects at this point: Inside 1000 yards, beyond 1000 yards, extreme long range, >=.300 calibre, 6mm/6.5mm, PRS....etc. And when I try and combine them into one discussion you try to narrow it back down to one of the stand-alones and cry foul because it doesn't align with the conclusion.
Can you buy them at Walmart? I accept that 6.5CM is more available south of the border, but it is still nowhere near as plentiful as .308 or .300WM, the latter which is of course also more expensive than .308. And you can still procure a .300WM rifle cheaper than you can a 6.5CM, and can do so in a 700, so that upgrades are relatively cheap. And there's some relativity here, .300WM is massively cheaper than .338LM or .416 Cheyenne and other "Unicorn" rounds.
On Midway, going by Lapua brand match ammo, .308 is $10.00 cheaper than 6mm Norma and $40.00 cheaper than 6.5x47mm Lapua (which is only available in that brand). They don't appear to make .300WM.
But if we do a search for .300WM, the Hornady Match is $32.99. Comparing it to the 6 and 6.5's: 6.5 Grendel is $21.99, 6mm Remington is $25.99, 120gr 6.5 CM's are $22.99, 140's are $25.99, .260 Remington is $30.79, .308 is $23.99....etc. There isn't a HUGE price difference here and 6.5CM is around the same price as .308 and .260 Remington is close to the same price as .300WM. The cheapest seems to be 6.5 Grendel. That $7/box difference between the .300WM and the 6.5CM is not huge.
Then consider this: You can buy the 700 Long Range in .300WM for $862.00 (probably cheaper elsewhere, that's Remington's price) with a heavy barrel and aluminum block bedded stock. They don't make a 700 in CM, so you'd have one built. Or, you buy the Ruger Precision for almost double the price, which doesn't guarantee any better accuracy, has WAY less aftermarket support, and at that point, at bare minimum, you are 100 boxes of ammo away; 2000 rounds, before the CM achieves price parity with the .300WM, assuming you exclusively feed both of them Hornady match. And then you are still stuck with a Ruger Precision that you can't upgrade like the 700.
Or of course you could do the same thing with the .260 Remington (available in the 700) but its ammo is still basically the same price as the .300WM, so the situation remains the same.
All of this would of course change if Remington made a 6.5CM heavy barrelled 700. But at this point they don't.
Thank you. My responses above.
All I was using PRS to show is that they use various 6 and 6.5 for what they do. They could use other more powerful rounds but don't. Therefore we can conclude the other rounds don't offer any advantage over the rounds they use for what they do.
You use hunting ammo to hunt. You use ammo that is better suited to shoot out to 1000 yard to shoot out to 1000 yards. You pointing out you can find hunting 300WM ammo locally but hardly see any 6.5 means little since you don't see 300WM match ammo on the shelves either at WM/etc. All are available online, or to handloaders, with 6.5 usually being cheaper. You can also make 6.5 CM and .260 brass from common .308/.243/etc brass.
6.5s are great 1000 yard rounds. That's been the basic premise. 6.5s also offer generally lower prices to shoot plus less recoil and blast than more powerful but no more effective at the task(1000 yards paper) rounds. Another point I always like to make is that not everything needs a 7mm mag and up to solve. 1000 yard shooting is another area where they are not needed.
I don't use the Walmart test in cartridge selection. I'm also not concerned with only the 6.5CM. There are a bunch of 6.5s. And even a bunch of 6mm, .25, .27, and 7mm plenty suited.
Cheaper is cheaper.
There are a lot of rifle makers.
The reason for this is that the more powerful rounds have more recoil which creates more delay between follow-up shots, which is not desired. In something where time is important like PRS, that's an issue. In shooting casually on weekends, it becomes less of one. I pointed this out in my initial reply to you on the PRS thing.
Yes, you use hunting ammo to hunt and plink with (at least that's what I use it for) because of its low cost and availability. And this ties into the affordability/ease of procurement point. If you are on a budget and using your rifle for hunting, weekend plinking and the odd competition, availability of ammo is important. If nobody stocks it (which is the case around here) and nobody stocks the rifles, what sense does it make to own for this purpose? It's a completely different scenario for somebody doing serious competition as they'll be handloading and spending tons of money on the rifle, but then the issue about the small difference in ammo price becomes irrelevant.
The Walmart test becomes important if you need to obtain ammo and can't. That's why hunting rifles are usually chambered in common cartridges. A cartridge being suitable is different from it being available. This is again important if you are looking to use your rifle as an all-around due to budget issues. This ties into my 700 example. That gun could be used for mild competition as well as hunting.
Cheaper is cheaper.
When the ability to obtain a reasonably accurate rifle in the calibre is hampered by the fact that it isn't supported by the majors and it requires having one built or buying something like the RPR, cheaper all of a sudden isn't.
That's not really a valid counter to the fact the 700 isn't available OTD in 6.5CM and its ilk. Either we are reasonably concerned about expense or we aren't. When you say "cheaper is cheaper" as justification in regards to a few dollars difference in the price between boxes of match ammo but dismiss the fact that the 700, the most popular precision rifle platform on the planet isn't available in many of these calibres and would require a custom build, well.....
Recoil and blast is always a consideration. Especially for less experienced shooters.
If you don't have suitable ammo for the situation you probably won't have a lot of success. I'm not sure what your argument is. Walmart doesn't have 6.5 or 300 mag match ammo. It's a non issue. You're going to have to go another route no matter what round you choose.
Using the Walmart test I should sell my .22s. They still don't have any. Nor any .357 Sig. It's a non issue.
Every accurate quality bolt action rifle can be used for hunting as well as mild competition. You want to pick specific examples and then apply it across the board. If Remington was the only place building factory guns you'd have a point. A local gun shop has a sporterized Swedish Mauser with a great looking bore. A nice scope and good handloads and it would probably be ready.
If you can't find a suitable gun then you get something else.
You're the guy caught up on 6.5CM and Remington. The 700 is available in .260 as you've pointed out several times. The CM is availble from other makers. The 6.5x47 by yet other makers. And then the 6.5x55. And even the 6.5-284.
$500 6.5 Creedmoor
Quote:
Finally, we took a long walk to a location where we could get a 1000-yard shot. The range was built on a recently harvested wheat field, and had steel targets ranging in size and distance from 200 yards to 1,000 yards. Fortunately the Kansas wind was taking a break for the holiday and we only had a 5 MPH full value wind blowing from right to left. I plugged some data into an iPhone app, put the data on the gun and pressed the first shot at 1,000 yards. There were a few adjustments made, but after the Predator was dialed in. It could not miss the 3’x3’ plate at 1,000 yards.
Ruger American Predator
Correction. $400
And there are plenty of cartridges for an inexperienced shooter to learn on including .22LR. We were talking about PRS and in the context of PRS, that's the reason for the choice of the cartridges they use: excellent ballistic performance at the range that they are working with and low recoil for quicker follow-up shots. My wife learned on .22LR and then migrated to .223, which also has low recoil. But she doesn't shoot PRS or competition, so she has the run of the gamut regarding cartridge selection with what the PRS guys use being wholly irrelevant to that choice.
Most people aren't looking for match ammo at Walmart, they would be looking for hunting ammo. My point is obvious: When you are using a rifle for multiple purposes, cartridge availability is important. Having to mail order your ammo does not work in the context of casual and spontaneous shooting outings. I often pick up ammo a day or so in advance when I go out, but sometimes I stop in at the gun shop or Canadian Tire to grab a few boxes on my way. I cannot do that with 6.5CM or its ilk. I can however do that with .300WM.
We have tons of .22LR (the big Remington Bucket-o-Bullets) in stock at Canadian Tire, Walmart....etc up here. The shortage south of the border is bizarre but is an exception. You can go in and get .308 or .300WM, probably 30-30, .270, .243, 30-06, 30-03....etc. My point still stands. Be honest: How much casual shooting do you actually do? Because it sounds like you don't have a lot of experience of trying to get ammo at the last minute for an outing and are subsequently using this as a justification for that scenario not existing. It exists, and the convenience of the big box stores having what you shoot in stock can not be ignored.
You completely missed my point. The RPR is twice the price of the 700. You can buy an entry level 700 and, as budget allows, upgrade it as you go. The 700 is only available in the "standard" cartridges, you know, the ones we are talking about that you can get ammo for at Walmart and the like, that's what makes them appropriate for those situations, their standardization. Competition rifles (the hardcore kind) are often chambered in cartridges that it only makes sense to hand load for. Sure you CAN hunt with them, but not many people do. The most popular cartridges for hunting are.... the ones that are stocked everywhere. That's not by coincidence.
In the context of building for mild competition, hunting and casual target shooting and with budget in mind, getting "something else" leaves us where? You compromise on something like the RPR with no clear upgrade path, what does that accomplish? For half the money you could buy a 700 in .308 or .260 and unless you are extremely good, will not see a difference in accuracy. That rifle can then be upgraded/built upon as budget allows. That's the idea of starting with the 700 family and why most people do; they don't just "get something else". How many of the 6.5 rifles out there do you think are based on a 700 action and the owner has had the rifle re-chambered? Many of these guys start with a standard cartridge and then work their way up as time and money allows and they get more serious into competition to the less available target cartridges which they hand load for. Usually these rifles lose their multi-purpose usage along the way and evolve into target-only rifles. Guys shooting serious competitions aren't buying Match ammo at Midway, they have thousands invested in hand loading equipment and have painstakingly developed the best rounds for their rifles at great expense. Subsequently the cost of match ammo for something beyond the entry level has next to no importance. And when talking about entry level we are back to talking about a rifle used for multiple purposes, which then brings us back to availability and ease of procurement which ties us back into being able to pick up ammo on a whim and the importance of budget.
The 6.5x47 Lapua is more expensive to shoot than .300WM, I pointed that out already. The CM is available from Ruger and Savage, both of which lack the support of the 700 platform. I'm not "caught up" on Remington, I'm expressing the importance of the commonality and support for the base rifle in terms of upgrade costs and viability moving forward in building on it. This is something that cannot be overlooked.
The Creedmore is the most "in vogue" 6.5, and the one you cited as having inexpensive ammo. I already provided costs for most of the others relative to the .300WM and .308, both of which have a far broader selection to choose from and massively better availability.
My CDX-33 is based on a 700-style action. Yes, it is a custom stainless action, but the 700 is the base. It has a Bartlein barrel, stainless custom bolt, aftermarket (CADEX) trigger, but these are all based around 700 parts. If I had used a 700 for the basis for my .308 build, I could use the same trigger, I could procure a similar bolt....etc. But since it is based on a Savage 10-series, my selections are more limited. It is a more expensive and more difficult rifle to upgrade and I've already spent north of 2K just putting it in a chassis.
"Budget" here has many facets; it carries not just a single face. Some of these are:
- Platform flexibility regarding future upgrades
- Cost of upgrade components such as chassis/stock, barrels, triggers, bolts....etc
- Cost of smith work
- Cost of initial procurement
- Availability of generic box ammo for casual shooting
- Availability of brass, powder, projectiles, primers and the like for hand loads for competition use and load development
These all have to be considered together to get an idea of overall cost, which is directly related to how far you want to go with that gun. For somebody who never gets really serious, something like the RPR may make more financial sense than building a 700. But if they intend on hunting with it, perhaps not. And if they plan on hunting with it, and regularly, as well as casual shooting, a standard (available) cartridge may make more sense than one of the potentially more accurate but less available precision cartridges.
That's the entire purpose of the RPR in 6.5CM. To capitalize on the current popularity of the cartridge and allow guys on a budget to get into the long distance game. The Savage Axis rifles are tackling it from the other end: Capitalizing on the popularity of the cartridge on the extreme budget end for the weekend plinker who is not aspiring to shoot great distances. The costs of these different approaches reflect that. In both cases you are compromising on a future upgrade path but have a product that should work well enough for its intended purpose.
If you want something that can "do it all" however, then you must consider the 700 family. It will have the best support in terms of smiths being familiar with it, the best availability of parts like triggers and barrels, the best selection of stocks that can do both precision and hunting. The best selection of precision trued actions, bolts....etc. The list goes on and on. And yes, you can build a 700 in any of the cartridges we are discussing, but that too carries with it a cost and this is all part of the "budget".
The real costs aren't in the difference between the various calibres of box ammunition. The real costs are the upgrades and the optics. The stuff you don't want to cheap out on. A NF, PMII, Steiner, Gen II Razor....etc, these are all thousands upon thousands of dollars. Then you need quality rings or a mount.
As I said, I'm far more concerned about my ability to GET ammo when I want it if I'm going out to shoot casually than I am about the cost differences between the cartridges we are discussing. $7/box is not a lot of money in that context and I would gladly pay that premium for a cartridge that is more readily available. However that premium was for match ammo and hunting/plinking ammo is generally even cheaper.
Ammo cost starts to become relevant when we start talking about .338LM, .416Cheyenne and the like. Cartridges that truly ARE expensive to shoot. 10 boxes of Hornady match (200 rounds) is over $1,000 down the barrel. Comparable box ammo for my .308 would be $200.00. THAT is a big difference and subsequently far more relevant than the cost difference between a 6.5 or 6mm cartridge and something like a .300WM.
Ultimately it isn't the cartridge cost that's the benefit for the less available 6 and 6.5's, it is the amount of accuracy they offer combined with greatly reduced recoil. You compromise on availability and pay a higher cost of entry to have a high performance cartridge that you can shoot comfortably all day, something that is difficult for many to do with the big 30's. In that context, if I were one making that compromise, I would build a 700 and it would be chambered in .260 for the best chance of finding box ammo. The lack of readily available box ammo kills it for me with the other cartridges.
$500 6.5 Creedmoor
Correction. $400
Yes, and a gun with very little aftermarket support, just like the Savage rifles. I've been down this road with my 10FCP-K, which is a bloody tack driver, but it lacks the upgradability of a 700 and if I were to do it again I would do a 700 stainless heavy barrel, fit it to the same chassis and upgrade it with a CADEX trigger and other goodies as I go.
The Ruger American is the basis for the Ruger Precision, so it is not surprising it would yield similar performance. For somebody looking to just buy and shoot and go no further with it I am sure they are fine. But for somebody looking for something they want to build off of they are a poor choice.
I'm done arguing this nonsense. My initial point was:
Seems easy for me to see the appeal. 6.5s are a cheap and effective way to punch paper at 1000 yards. Sure, you can also do the same with a twenty pound four feet long $5000+ cannon chambered in $5 bills but a hole is a hole.
That assertion has been backed up with links to $400 new factory rifles with documented performance at 1000 yards, and $23 and up match ammo. Case closed.
Nobody is going to use a $400 rifle to shoot even semi-competitively.
The 6.5's in the above post are being referred to collectively but there is a marked difference in cost and availability between the various chamberings with some being quite expensive, like the Lapua. The primary advantages they offer are indeed mostly common and these are increased barrel life and significantly reduced recoil coupled with exceptional performance. The primary disadvantages are lack of availability in both cartridge and rifle selection at most retail venues as well as the distinct absence of them in the Remington 700 lineup, the most common precision rifle platform on the market.
Subsequently we should, as I have done early on, look at each offering individually. The only example that aligns with my expectations is the .260 Remington, available in the 700 family and has been around since the 1990's, far longer than cartridges like the Grendel, Creedmore and Lapua. Subsequently being able to procure box ammo for it on a whim is far more feasible. Nowhere near as plentiful as the traditional hunting rounds, but available enough to make it a decent fit for an application where 1000 yard shots are to be mixed with weekend plinking, hunting and the like. Bringing with it the advantages of these similar cartridges while minimizing the disadvantages.
hatt: Your persistence has inspired me. I'm now shopping for a stainless 700 in .260. Should be a nice fit between the .308 and the .338LM.
