Can LC be added to radiator/coolant?
Originally posted by axjohn:
If so, at what ratio? TIA.
I think a better choice would be a quality antifreeze like Zerex G-05 and if that isn't enough then add the Prestone or Zerex system conditioner/water pump lube stuff
the prestone has petro dists in it
Originally posted by Neil Womack:
Try this experiment.
In a small bottle take equal parts water and LC. Now shake to see if the LC is water soluble.
The real test should be whether a 50-50 water-EG mix can dissolve a small amount of LC.
Can't remember which thread, but I read it here on BITOG that someone (Otis?) uses it in radiators.
axjohn, Yes, that's correct. Terry mentioned, he used LC in the radiator in his daughter's honda and Odis also used LC in the radiator that what Terry mentioned in other thread. I could not find where is it.
