On the beater camry that my parents drive. They had jiffy lube cross thread and strip the drain plug a while ago before i started to do their oil changes. I was [censored] they charged them $39 for conventional oil changes.
So after i found out that they screwed the drain plug. Kinda went back and fourth with getting an oil pan or doing a oversized plug since we dont really plan on keep the car super long.
I found a piggyback plug.
http://www.autozone.com/autozone/accesso...entifier=232418
This is oversized plug with a 10mm plug at the back end so i dont screw up the threads anymore. But pass couple oil changes have taken WAY WAY too long. To drain it would like 30 minutes, in most cases i could rotate the tires, top off all the fluids, clean up all my tools and it still draining.
I'm thinking of going back to a normal plug but obviously the oversized self tapping ones. Can you keep using or will the threads give out after a while?
