Motor on 02 Envoy has intermittent knock, not bad when warm, can't really hear it when cold...but from about 3 min after a cold start until hot there's a knock or tap but I don't think it's a rod. The motor is the 4200 Vortec Inline 6.
I have cut open last 2 oil filters and there is nothing but some slight black grit deep in the peats and only in a few pleats, don't see any distinct metal bits or gold.
The oil pressure gauge isn't a real gauge but it's slightly slower to rise then from about a year ago. I change oil realistically every 5-6K, mostly synthetic.
I want to say the noise is in the valve train, I don't really hear it underneath as much but mainly around or just below the valve cover.
I pulled the coil packs one by one and zero change in pitch, I even pulled the coil in the previous firing sequence and still no change.
I have just changed the oil to Castrol Edge and I want to say when the engine is hot, that the noise isn't as pronounced. To remove the oil pan is a major PITA on this vehicle especially with 4WD. I was thinking I could possibly install a sandwich adapter at the oil filter housing and reverse flow some solvent into the oil pan without damaging any seals.
I don't know if there is a one-way valve in the pump but would this be possible? I figure if I could do this and knock some debris out then maybe it's an oil starvation issue. I can open the oil fill cap and see a good film of oil hanging on to the front of the cam phasers but anything is possible.
Maybe drain a quart and add 1qt of ATF,I really don't want to pull the pan but if I do I'm going all out and pulling the timing cover and changing the pump....MAJOR PITA.
