Can Anyone Identify These Nylon Lined Sockets?
Vancouver, BC Canada
Per the title , can anyone recognize the brand / mfr with these nylon lined 6 pt sockets? I would like to get a 19mm one to use on the lugnuts on my Mazda6.
I know, right?
The only thing I can't read is the brand name; for crying out loud!
Does is have to be this brand?
An internet search should come up with something in any brand name for your need.
Some lug nut sockets have an outside sleeve to prevent scratching your wheels.
Those are specialty sockets not lugnut sockets.
Looking closely, the wall of the socket (in steel) is not hex shaped. Weird, though they indicate 200 ft lbs max? Are the nylon inserts bonded to the steel? Yes I know how traditional lugnut sockets have plastic outside. I acually want plastic inside, outside, plus on-end. Is there any such thing? How 'bout aluminum sockets?
I am guessing these nylon insert sockets are made for use on nuts of similar material.
For wheel lugs the sockets with the nylon exterior are what is needed.
I have a set like this
https://www.amazon.com/Astro-7870-Protective-Plastic-Shallow/dp/B00061SGR2/ref=sr_1_6?ie=UTF8&qid=1538757354&sr=8-6&keywords=lug+socket+set&refinements=p_89%3AAstro+Pneumatic+Tool
[Linked Image]
I have to say that harbor freight has a set that looks about identical for less. I think they are the same manufacturer.
https://www.harborfreight.com/12-in-drive-sae-metric-lug-nut-impact-sockets-7-pc-69781.html
[Linked Image]
Originally Posted by rooflessVW
^ I've got the same set. Works well as long as you keep them off the impact.
I just use them with a torque wrench for tightening, I may have used them once with an impact for removal. Will they crack under impact use?
Almost certainly. I won't take the chance with these or my regular sockets. Only high-quality impact sockets see my gun.
Thanks, i'll keep them off my aircat.
