Calculator for viscosity mixing based on the Lederer - Roegiers equation
Paramount, California
I just realized that the Widman viscosity-mixing calculator and similar calculators on the Internet are totally useless. They are very inaccurate.
After some brief reading, it looks like the Lederer - Roegiers equation works well. The only caveat is that there is an adjustable parameter alpha that accounts for the intermolecular cohesion energy, which ideally needs to be determined empirically.
Here is the article I read:
Viscosity-blending equations
Boris Zhmud, Ph.D., Assoc.Prof., MRSC
Sveacon Consulting, Stockholm, Sweden
Lube-Tech, No: 93, Page 1
http://www.lube-media.com/wp-content/uploads/2017/11/Lube-Tech093-ViscosityBlendingEquations.pdf
I created a spreadsheet that you can plug in your values to calculate the blend viscosity:
[Linked Image]
Here is the link for the calculator. Enjoy!
Gokhan's viscosity-mixing calculator based on the Lederer - Roegiers equation
Some clarification on alpha:
alpha = 1.0 for mixing similar oils.
Typical alpha values for mixing some different oil types are listed in the image as well as the spreadsheet.
Clarification on dynamic vs. kinematic viscosity:
You need to use the dynamic viscosity. However, if the density values are not available, you can use the kinematic viscosity with reduced accuracy.
dynamic viscosity (DV) = density * kinematic viscosity (KV)
Density varies as a function of the temperature. You can use this table to estimate it for different temperatures (the exact rate of change with temperature varies with the oil):
Code
T (°C) density(T)/density(15.6 °C)
15.6 1.000
20 0.997
30 0.990
40 0.983
50 0.976
60 0.969
70 0.962
80 0.955
90 0.948
100 0.941
110 0.934
120 0.926
130 0.919
140 0.912
150 0.905
160 0.898
170 0.891
180 0.883
190 0.876
200 0.869
[Linked Image]
Cool, thanks. That might account for the strange behavior of a mix of a relatively viscous polymer ester and paraffinic base oils in which the mix viscosity is much less than the simple calculators predict. Do you now need to update your spreadsheet that shows the HTFS viscosity or is it close enough?
You're welcome! The calculation for the HTFS viscosity for a single oil doesn't use the viscosity-mixing calculator. I was asked to calculate the HTHS viscosity of two oils mixed/blended together and I wrote this calculator so that I can use it in that calculation:
https://www.bobistheoilguy.com/foru...erature-full-shear-viscosity#Post5141467
In addition to the DV calculator, which can be used at any temperature, I have now included calculators for KV40 and KV100 as well.
Nevertheless, there seems to be very little error in using the DV calculator for KV mixing. So, if you don't bother, use the DV calculator (first calculator) for KV mixing as well. If you're worried about the accuracy, use the KV40 and KV100 calculators (second and third calculators) with the respective KV values.
Gokhan's DV and KV viscosity-mixing calculators based on the Lederer - Roegiers equation
[Linked Image]
Here are the equations for viscosity mixing/blending.
___________________________________________________
Arrhenius equation:
n = n1^x1 * n2^x2
Lederer - Roegiers equation:
n = n1^x1_effective * n2^x2_effective
with
x1_effective = x1 / (x1 + x2 * alpha)
x2_effective = x2 * alpha / (x1 + x2 * alpha)
These are the descriptions of the variables:
^ represents exponentiation: a^b = a raised to the power of b.
n = dynamic viscosity of the mix/blend
n1 = dynamic viscosity of oil 1
n2 = dynamic viscosity of oil 2
Note that the dynamic viscosities should be measured at the same temperature for both oils and the mix/blend.
x1 = fraction of oil 1 (between 0 and 1)
x2 = fraction of oil 2 (between 0 and 1)
Note that x1 + x2 = 1.
alpha = coefficient to account for the relative intermolecular cohesion energy of oil 2 with respect to oil 1
alpha = 1 if oil 1 and oil 2 have similar molecular structures; otherwise, alpha < 1 or alpha > 1 depending on how oil 2 differs from oil 1.
If alpha = 1 (oil 1 and oil 2 have similar molecular structures), Lederer - Roegiers equation reduces to the Arrhenius equation.
x1_effective = effective fraction of oil 1 correcting for the difference in the intermolecular cohesion energy of the two oils
x2_effective = effective fraction of oil 2 correcting for the difference in the intermolecular cohesion energy of the two oils
Note that x1_effective + x2_effective = 1.
Example:
If you have a 50/50 blend of an oil with a viscosity 16.0 cP with an oil with a viscosity of 8.0 cP, then the resulting viscosity of the mix/blend is:
16.0^0.5 * 8.0^0.5 = square root(16.0 * 8.0) = 11.3 cP
In other words for a 50/50 mix/blend of similar oils, the viscosity of the mix/blend is the geometric average of the two viscosities (11.3 cP), not the arithmetic average of the two viscosities (12.0 cP).
Finally note that while these equations are for the dynamic viscosities in cP units, they can also be used with good accuracy for the kinematic viscosities in cSt units. (dynamic viscosity = kinematic viscosity * density, with the density measured at the same temperature as the viscosity.)
Are you going to go back and correct all the posts you made that were premised on them being nigh on the level of physical constants? On a constructive note, an equation renderer might be of value here.
As an analytical chemist(retired) Gokhan's equation raised a lot of red flags as to potential inaccuracies. He's taking a formula that is specifically for a binary mixture and applying it to a mixture of two multi component mixtures, which is definitely not a binary mixture. The equations obtain their accuracy by empirically deriving alpha for each binary mixture at a single mixing ratio. Gokhan is guessing alpha.
The accuracy of the Widman calculator and Gokhan's equation can be easily and economically tested. All we need to do is compare the results of the two methodologies to measured values. To that end, I contacted Blackstone and they will do viscosity cSt @100C for $10 each. I'm willing to buy 5-7 oils and pay for 12 analysis. That should give us a reasonable idea how things fall out of the equations.
My plan would be to do mixes of oils of at least two SAE grades apart and of differing base stock mixtures. The mixes would be be biased toward differing brands, wide viscosity differences, and ratios other than 1:1, but would include mixes of the same brand line and mixes of similar oils from different brands.
Gokan would supply data from the methodology proposed in this thread, Garak could supply the Widman calculations, and I will provide the measured values. Is everyone game?
Ed
Clarification:
alpha is an adjustable empirical constant that you can only determine by mixing/blending two oils and then actually measuring the viscosity of the mix/blend. You then adjust alpha until the theory agrees with the experiment. Once you know alpha for the two oils you are mixing/blending, you can use it to calculate the viscosity of the mix/blend for different fractions of oil 1 and oil 2.
If you don't know alpha empirically, you can assume that alpha = 1 (as the Widman mixing/blending calculator does but it also does some strange things I don't understand) and go from there. This assumes that oil 1 and oil 2 have similar base oils with viscosities in the same order of magnitude. For two oils with greatly differing base-oil types or viscosities, you can use the table to guess a better alpha but it will only be a rough guess.
I'm on board!
I have oils and a plan. The order for sample bottles apparently fell though the cracks at Blackstone. I called this morning and bottles are now on the way.
I'll be doing the mixing using Class A graduated cylinders. What? You don't have Class A measuring equipment in your bar kit?!
Ed
Blackstone has had the samples for a week. No data yet. I'm leaving for a camping trip on Wednesday. If I don't get the data by Tuesday night, I won't get it posted until the following Tuesday.
I'm looking forward to getting the results of this experiment. It took close to three hours to do the mixing as getting a precision that I was comfortable with took long drain times from the cylinder. If you want an oil that will cling like crazy, Redline 50WT Race Oil is the cat's pajamas!
Ed
Here are the data for the viscosity calculations. I tried to pick combinations that replicate common mixing practices seen on BITOG. The first is the classic 50:50 Mobil 1 0w-40 and 0W20. The rest simulated adding a quart of heavier oil to thicken things a bit, or a quart of thinner oil to thin things down a bit. There is also the practice of adding a quart of Redline as an "additive". Other mixes are intended to test the equations with differing base stocks and viscosity ranges.
As you can see, the measured viscosity varied significantly from the published "typical" viscosity in some cases. The data came from U.S.A. region PDS sheets published directly on the oil manufacture's web site. In the case of Castrol, the sheet for the GTX 20W-50 was dated 2012. The data for the Valvoline SAE 30 ND was from 2006, which was current when the oil used was purchased. The other oil's data are current.
These are the calculations I'd like to see run at a minimum:
Widman measured cSt.
Widman PDS cSt.
Gokhan's calculator measured dynamic viscosity, estimated alpha from tables in calculator(state number used).
Gohkan's calculator measured cSt., alpha 1.0 for all.
Gokhan's calculator measured cSt., estimated alpha from tables in calculator(state number used).
Gokhan's calculator PDS cSt., alpha 1.0 for all.
Gokhan's calculator PDS cSt., estimated alpha from tables in calculator(state number used).
Those combinations will allow us to see how much error is introduced by the difference in a measured viscosity vs, typical, the calculation methods, and the effect of adding an estimated alpha into the equation. Once all the data has been posted I'll post the measured values for the mixes. At that point, someone who likes to play with Excel can wrap it all up in a neat, informative table.
The oils:
Oil (Measured cSt@100C) [PDS cSt@100C, PDS density g/[email protected]]
Mobil 1 Extended Performance 0w20(8.18) [8.6, 0.839]
Mobil 1 0W-40 FS (11.73) [12.9, 0.8456]
Castrol GTX 5w30 ULTRACLEAN (9.56) [11.0, 0.862]
Castrol GTX 20W-50 (17.21) [18.09, 0.884]
Redline 50WT Race Oil (17.29) [19.2, 0.897]
Valvoline SAE 30 ND (10.86) [11.0, 0.889]
Rotella T5 10w30 (11.34) [12, 0.869]
The mixes:
Oil 1(fraction) - Oil 2(fraction)
1. Mobil 1 0W-20(0.5) - Mobil 1 0W-40(0.5)
2. Mobil 1 0W-20(0.2) - Mobil 1 0W40 (0.8)
3. Mobil 1 0W-20(0.8) - Mobil 1 0W40(0.2)
4. Castrol GTX 5w30((0.2) - Castrol GTX 20W-50(0.8)
5. Castrol GTX 5w30((0.8) - Castrol GTX 20W-50(0.2)
6. Mobil 1 0W-20(0.5) - Redline 50WT Race(0.5)
7. Mobil 1 0W-20(0.2) - Redline 50WT Race(0.8)
8. Mobil 1 0W-20(0.8) - Redline 50WT Race(0.2)
9. Mobil 1 0W-40(0.2) - Redline 50WT Race(0.8)
10. Mobil 1 0W-40(0.8) - Redline 50WT Race(0.2)
11. Castrol GTX 5w30(0.5) - Rotella T5 10W30(0.5)
12. Mobil 1 0W-20(0.2) - Castrol GTX 20W-50(0.8)
13. Redline 50WT Race(0.5) - Valvoline SAE30 ND(0.5)
Ed
I received a PM from Gokhan and he indicated that he would like someone else to do the calculations using his calculator at this time. I'll excuse myself from doing the calculations as I've seen the results and don't want to chance introducing any unintentional bias into choosing a value for alpha.
Garak, MolaKule, Shannow, or anyone else who would like to plug in the numbers, please feel free to do so.
Ed
Great work, Ed!
I was able to get to it briefly.
I tested both spreadsheet calculators in my original post -- the first one using only the kinematic viscosities (KV) and the second one also using the densities. The error in using the simpler calculator was between +0.00% and +0.06% -- always very slightly overestimating the KV of the mix -- and it's obviously entirely negligible given the accuracy of the KV values. Therefore, from now on, I will only use the Lederer - Roegiers formula, which is
with
so that I plug in the KV values into the n's instead of bothering to convert them into the dynamic viscosity (DV).
Using alpha = 1, here are the results for the KV100 of the mix in cSt. I calculated them both using the Blackstone values (first column) and PDS values (second column).
Code
Mix # Lab PDS
1 9.80 10.53
2 10.91 11.90
3 8.79 9.33
4 15.30 16.38
5 10.75 12.15
6 11.89 12.85
7 14.89 16.35
8 9.50 10.10
9 16.00 17.73
10 12.68 13.97
11 10.41 11.49
12 14.83 15.59
13 13.70 14.53
As far as the alpha is concerned, it can only be determined empirically. When the experimental results are presented, we can calculate the alpha to see if it makes sense.
A concern that remains is the accuracy of the Blackstone KV measurements. Typical commercial viscometers seem to have an accuracy around ±3%. Therefore, we shouldn't expect an agreement with the theory beyond about ±4%, which is about ±0.4 cSt, when two different oils with measured viscosities are mixed. In fact Wear Check told me that the error in a single KV measurement is "less than ±0.5 cSt," which is consistent with this observation: accuracy around ±0.3 cSt for a single oil and ±0.3 cSt × √2 ~ ±0.4 cSt for two different oils mixed together.
Code
Mix # Lab PDS
1 9.80 10.53
2 10.91 11.90
3 8.79 9.33
4 15.30 16.38
5 10.75 12.15
6 11.89 12.85
7 14.89 16.35
8 9.50 10.10
9 16.00 17.73
10 12.68 13.97
11 10.41 11.49
12 14.83 15.59
13 13.70 14.53
Here's the Widman data including the lab values for the mixes:
Code
Mix # Lab PDS Lab Actual
1 9.77 10.49 10.14
2 10.89 11.86 11.11
3 8.77 9.30 8.95
4 15.21 16.31 15.08
5 10.69 12.10 10.61
6 11.73 12.64 11.38
7 14.75 16.17 14.66
8 9.42 10.00 9.37
9 15.96 17.68 14.86
10 12.65 13.93 12.20
11 10.40 11.49 10.12
12 14.69 15.45 14.44
13 13.63 14.42 13.12
OK, you statisticians, have fun!
Ed
Darn it, friggin dyslexia! Even after checking the table twice, I managed a Typo. The measured viscosity of mix #7 should read 14.75 not 17.75. Could one of the moderators please correct the table?
Ed
