C3 and A5/B5 compatibility with older cars
Brittany 🇫🇷
I must say i have a hard time understanding these ACEA ratings. For a lot of cars i prefer to use a 5w30 however is has become impossible to source an A3/B4 oil locally or even for a good price on the internet.
What kind of 5w30 should be used in olders cars ? I am talking 90s/early 00s regular gas engines calling for something like API SG/SH/SL or ACEA A3/B3. Let's take my own car, the C180 as an exemple but this includes various Renaults, PSAs as well as some japanese and american cars.
I will take these two oils as an exemple as they are some of the most popular. What should be used and why ?
Total Quartz INEO Long Life 5w30
Total Quartz 9000 Future NFC 5w30
Originally Posted by Jetronic
Get Total quartz 9000 energy. All 3 can run on that without issue and it's not expensive.
Which oil in particular are you talking about ? I did not find it in 5w30, i know it exists in 0w30 but way to expensive.
I rember you and your dilema a year ago.....
Since you are from France.....Leclerk has nice oil stash..for cheap ( Its most probably repacked Shell...)
ex Extralube.....a.k.a Tech9 nowadays
5w30 C3 504/507 (see my sig)
or 5w40 (or even in 10w40)
https://www.e-leclerc.com/catalogue/marques-distributeurs/tech9/auto/entretien-auto/huile-moteur/huile-moteur-5w40-diesel-2l-tech9--,41009
https://www.e-leclerc.com/catalogue/marques-distributeurs/tech9/auto/entretien-auto/huile-moteur/huile-moteur-5w30-filtre-a-particules-c3-2l-tech9-,41013
I (personally) would not use oils with HTHS lower than 3.5 in "old" cars.....ie Acea A5/B5 A1/B1...C2...C1
Thank you ! Tech9 is usually what i buy when i need a 5W-40, it is Avia oil. So C3 is the closest to A3/B3/B4 ?
