Here is a cut up GM transmission filter from my 6L90 that was run from 150,000 miles to 200,000 miles. The housing is hard brittle plastic so I used a set of garden shears to smash the edges of it to open it up. I found two sheets of filter material measuring about 0.07 inches thick. The inside of the housing had vanes to direct the flow from between the two sheets. The in-flow was between the sheets. What I found was fine metallic particles. This is a real filter and not what some folks call a “ Rock Catcher”. Enjoy.
