I want to replace the FL820s filter with a larger Baldwin filter(B281). It is my understanding that the FL820s has a bypass valve rated at 8psi,the Baldwin bypass is rated at 20psi. Is the difference in bypass valve pressure going to be a problem; 8psi vs 20psi? The engine is 5.4L 3v engine in a 2004 F150.
