labman:
You're touching on a subject that I have mentioned before.
In your instance you used one part number, OEM at that, and have seen three different medias ( and constructions) over time.
The first answer is all three met or exceeded OEM specs. Even though they all were different.
As you noted the media changed in the three.
Again, this could primarily be due to the differences in the amount of synthetics added to the media blend.
If you were more specific about the number of pleats and other visual information..then maybe I could get a bit more specific.
But i'll give it a shot anyway.
It is possible to have more pleats with cellulose, go to less pleats when synthetics are added, then add more pleats with the synthetics because of complaints there were less pleats. I've seen that happen with customers...
So you have X efficiency with cellulose and a larger amount of pleats and Y dirt holding capacity.
Go to better efficiency with less pleats and equal or better the dirt holding capacity.
Then add more pleats with the better efficiency and have even more dirt holding capacity.
and all three "meet or exceed"...
