I've got something to add to this topic, Hopefully someone can explain this to me....
I have a Nissan truck, 1989 with a 2.4L engine.
(Original Fram equivalent for this truck was the ph43) I use the MC Fl-300 filter which has a bypass in the filter because there is no bypass in the filter mount. Over the years I have used other brands of filters but they were all comparable both in having a bypass and in physical size.
The filter that current books show for use in this truck is the Fram ph3682 equivalent- which is a smaller filter that does NOT have a bypass.....
I understand that sometimes smaller filters may be used for several vehicles so they may be considered a "generic/universal" size...but in this case they have now done away with the bypass functionality....someone who doesn't know about that may be using them and now they do not have an oil filter bypass on their truck....
I called the local Nissan dealer and he said they still show the older, larger filter that I am using the equivalent.
Just for reference here,
MC Fl-300 (purolator clone) -> 293 sq in of media
AC PF20 -> 243 sq in of media
Penske Maxpro CM43 (Wix clone) -> 263 sq in of media
These 3 filters have the bypass located at the inlet side of the filter (NOT at the far end like the FRAM version does...)
Anybody can explain this to me why the aftermarket folks think this vehicle no longer needs a bypass?? It hasn't grown one in the block anytime since I bought it in 1989...
