My MBE 902.912 (6.4L 6 cyl engine originally with EGR) has a factory centrifuge. With EGR and 228.3 oil (good CI4+ 15W40) it specifies an OCI of about 550hrs depending on fuel consumption rate (about 20000 mi).
The same engine without EGR in Euro 4/5 trim recommends 1200 hr OCI (about 45000 mi) with 228.5 oil (synthetic E4 meeting MB's higher specs). Interestingly, no centrifuge is fitted; the main reason it seems be on mine is the high soot input of EGR.
I removed the EGR and replaced it with a steel plate. I haven't dared going past 22000 mi yet, even with 228.5 oil. If the situation calls for it, I may do successive used oil analysis at 20, 30 and even 40K miles. It has a 29L sump and uses 1L every 2500 miles.
Charlie
Charlie
