Buying aircraft is fun to do...
Ca USA
Andrew, my trusted designated driver, was traveling in our 2017 V6 Camaro while towing my new 250lb Hummel Ultralight Cruiser from the previous owner at Regina Canada to Sacramento a distance of 1,700 miles one way, when someone on Reddit recorded and posted this video... we really enjoyed reading the comments...
Reddit Video
"Don’t own a camaro, but thought you’d enjoy this camaro i saw towing a plane down the freeway"
In the box on the floor painted red is the 45HP 4 stroke Casler engine which is 1/2 of a VW...
That is so cool. The Hummel company is only an hour away from me. Go figure.
Keep us posted! Thank you.
250lb? A lot of the small utility trailers are known for bouncing around unloaded. Did you adjust angle so as to get the right amount of down force? [I realize much of wing structure is gone, but still, that was my first thought--this is a low speed plane, right?--so if you drive fast enough, can it generate enough lift to make handling "fun"?]
This little guy appears to be of all metal construction and it only weighs 250Lbs?
Wow!
Why is the left elevator sharply down and the right one perfectly in trail?
Not yet rigged?
