I have a 1976 Hahn push mower with a 4HP Briggs engine. It's the old white engine, with the auto choke set up.
I have taken the carb down and cleaned it, and put in a new air filter... and a carb base gasket/diaphragm thing... the choke seems to be working right.
If you tip the mower, spark plug side down, for a few seconds she'll prime an start right up. But it won't keep running.
I don't know if the problem might be the fuel pick up... the screen on the end of that tube wasn't clogged, and I actually removed the screen just in case it might have been clogged... but the problem persists.
I can mess with the richness mixture screw a bit, and prime the carb and get the mower to run for a while... maybe to mow for an hour sometimes, but when I go back to use it next time, it's the same thing all over again... tip it for a few second to prime the carb, then it'll start and run about 2 or 3 seconds, then quit.
Any ideas?
Thanks in advance,
Dan
Any ideas?
Thanks in advance,
Dan
