Break in oils/procedures for new head/cam/valves/
Manchester, England
Hello Everyone,
I have a question and I think I know the answer but want to clarify & confirm
I bought a used engine from eBay and pulled the head off, sent it for porting/polishing/bigger valves/worked manifolds etc. I also sent a USED camshaft to be included in the build and the valve lash has been set using solid shims which are NEW parts.
Does this combination of new&used valve train parts have any special requirements or techniques for running in? Or just drive it like normal and change the oil after a couple of hundred miles?
Looking forward to your responses
If it was flat tappet, then you are likely doomed to fail.
Wife's Captiva had a recall for bad rocker arms, which they were prepared to install on the old cam (fine really, not flat tappets)...they had to do the cam as well, so it's new cam/new lifters...half way through an OCI, and the tech said not to bother changing it early.
Which was fine by me, used oil has more reactive additives.
The cam shouldn't be a problem but I would use some assembly lube on all the parts and lobes. Use a little zinc additive in the oil and bring the RPM up to about 2K for 15-20 min and it will be fine.
If this is a VW vacuum fill the cooling system so you don't have the bleeding fiasco and overheating issues. Leave the oil in for 1K then change it.
Just curious why you do a cam break in procedure on a used cam? It obviously doesn’t hurt it but if the lobes already have wear in, he should be able just to turn it on and go.
The discussion does not sound like a flat tappet. More like an overhead cam with shim adjusters ... If that's the case, I would not be overly concerned. But ...
You are have some serious head work done. That means you are bumping the HP and likely moving the Tq peak up the RPM range. Which will put extra stress on the cam and valve train. So the question is have you made allowances for additional oiling?
He said addition work with the valves was done its possible they used heavier springs that could put additional stress on the lobes.
New shims may look nice and shiny but they need some run in time also to match. Its usually no problem but I do anything I can to help old parts wear in to new parts, assy lube is cheap insurance.
VW have no oiling issues that I am aware of on the top end.
I was thinking of buying a qt. of Redline Race oil and lubing the top end with it just before fitting the valve cover and starting it up for the first time but assembly lube will stick better if it doesn't fire on the first turn.
Wold it be worth changing the oil just before the head swap to minimise particulates or is it the case that if they're small enough to pass the filter they won't do any measurable damage?
Thanks for your input
For sure, I would run assembly lube and a zinc additive for the for quick change if it's an old vehicle without sensitive emissions equipment (hopefully since it's getting this much head work
I don't know about machine shops in the UK but here they usually don't make any recommendations (at least in writing), they leave that up to you they dont want to held responsible if something goes afoul.
Remember this is a country where a old woman spilled coffee on her crotch and sued McDonald's because the coffee was hot and won 2.8 million.
