JHZR2
Staff member
Hi,
Maybe this belongs in the lawn and small engine forum, but I think the discussion is better suited to here. I am going to be breaking in some yard equipment, which is specced for 10w30 or SAE 30 oil... Some of it is allowed 40 wt oil as well, though its by no means a necessity for the operating environment that I'm in.
I'd like the break in with a good high dose of moly... Im thinking that Id rather start with a straight 30, since I will be using a conventional oil, prior to switching to Amsoil 30/10w-30 diesel oil.
What would you suggest as a good break in oil and why??? Im considering three diferent 30 straight weight oils: Exxon, Havoline and pennzoil... exxon because it seems to be pretty full of moly, havoline because it seems to have very large doses of moly and gives consistently excellent results, or pennzoil, because it is a trusted name that I know has a top notch add pack and will also give great results.
I havent seen many VOA or UOA on straight weight oils, for obvious reasons, so cant be sure that their add packs are as good as those for say, a 10w30... would that be a good reason to use a 10w30 instead???
Or would I just be best off breaking in on delo 400 15w40, as its got stronger adds and moly?
Your suggestion would be appreciated.
Thanks,
JMH
Thanks,
JMH
