Hi folks:
Slow motion brake job here - I have been messing with the brakes on an 07 Mazda 6i for going on a month. Replaced the front pads, brake fluid change / flush, and did couple bleeds to removed any air.
Now the pedal is hard before startup - which is different than before. After starting it drops slightly, and everything feels normal.
Does this indicate a master cylinder or vacuum booster leak, or did I just have a ton of air in the system?
For background - the pedal originally felt squishy under braking (like there was air in the system), and I did all this to improve the initial "bite." After a few bleeds and activating the ABS a couple times, it feels better, except for when I first get in and turn the car on.
Thanks guys - this is probably my 4th or 5th post on this - and the input has been helpful.
