Brake fluid to remove wax residue on rubber trim
Suburban Washington DC
Tried wax and grease remover which did nothing. Tried some brake fluid and it worked. Obviously don't get it on paint. This was on the back window molding next to the glass so not an issue.
Before
After
Might need to go over it a few more times, but better than it was before.
Before
After
My father told me once they used brake fluid on rubber items and as tire dressing back in the day
PimTac said:
“Free country- do what you want. Atikovi used it and it worked well for him. Brake fluid is used in rubber brake components, so it probably willl not hurt window seals, rubber, or tires. Just be careful around painted items”
I don’t remember posting this but the caution of using around painted surfaces still applies.
Again, it’s not something I would do.
I've used pink pencil erasers to remove wax residue like that on black plastic. I'm not sure if it would work on a pliable seal like that, but it could be worth a shot?
