I have been researching brake fluid for a bit now to determine if a switch from DOT 3 to DOT 5.1 makes any sense for our vehicles. The one I'm most concerned about is our 2018 LEAF EV which calls for yearly fluid flushes, and has a very expensive integrated electronic braking system. We also see winter temps that can dip below -35C, so choosing a fluid with very low viscosity at low temps makes sense.
I found some nicely detailed and recent (2019) data from a study conducted by the US military to evaluate DOT 3, 4, and 5.1 fluid as an ABS friendly alternative to DOT 5 (silcone based) which does not work with ABS systems. The study really clears up some ambiguous information floating around on the interwebs.
Some key points:
I've attached two links...the second gives you an idea of the brands uses, but the study does not explicitly say which is which. I surmised that the DOT 5.1 C brand is the Bosch ES16-32N (DOT 5.1) based on its kinematic viscosity numbers at -40C. The DOT 5.1 E candidate may also be the BOSCH fluid, again just based on their spec of 680 mm2/s at -40C, compared to the measured results. This is what I'm standardising our vehicles to on a 2-3 year flush schedule. I'm using the Speedibleed pressure bleed system with correct caps for Honda, Nissan and Toyota...which works very well for a 1 person DIY setup with no two person pump/bleed required. I have tried vacuum at the calipers and it always required a pressure bleed to get a solid pedal..so I don't use this method any longer.
In any case, I hope this dispels some anecdotal myths floating around, and prompts some intelligent discussion on the matter
This is the study:
This is the market research on brands for the study. Note that a few of these manufacturers are bulk suppliers, so the actual brake fluid brand cannot be inferred. Look to the last page:
I look forward to your comments based on the study and perhaps some detective work on matching brands to the candidates.
Some key points:
- This research confirms more or less confirms that DOT 3 absorbs less water than 4, and DOT 4 less again than 5.1.
- They test EPDM vs SBD rubber parts/seals for swell/hardness and my interpretation there is that it's a wash.
- DOT 4 doesn't look so good in their tests.
- Corrosion results on the various fluids (other than 1 of the DOT 4 candidates) show excellent results on all the fluids.
- It looks like the DOT 5.1 will replace the silcone DOT 5 standard for the military.
- The DOT 3 LV (I believe this is Dow Brake Fluid 372LB) shows the best viscosity at very low temps (of all the fluids tested), the least water uptake, and very low corrosion numbers.
- The ? Bosch ES16-32N showed the highest boiling point for wet (4%) fluid.
This is the study:
